Results 1 to 3 of 3
Thread: Rail pressure ramp at startup
    Member arinkuddy's Avatar
    May 2014
    Default Rail pressure ramp at startup
    I have some white smoke at startup so I was playing with increasing my rail pressure and on this tune I set idle to a flat 70MPa. I noticed this strange ramping of the desired rail pressure. The ramp appears to be a constant slope at about 2.5MPa/S. I was wondering if anyone has ever run into this or knows if there is a way to increase the slope of this ramp.
    log in picture: CMB_0141.efi
    stock: CMB_0140.efi
    Senior Member tylerltr450's Avatar
    Aug 2014
    Quote Originally Posted by arinkuddy View Post
    stock: CMB_0140.efi
    Arin, Do you think it is related to air temp coming across the sensors, which may increase fuel demand which could could consider kicking in high idle?
    Good to see you are still playing with tunes!!!
    2006 Cummins Red, Auto to Nv5600, SBC 3600, Traction Bars, Visor, Running Lights, S&B Intake, ATS intake horn, EFI Live, Borg Warner S363 Turbo, Industrial Injection Dragon Fly Injectors.
    May 2014
    It really looks like a time based ramp function to me. Just thought it was kinda odd and I don't see the purpose.
    What I was really wondering was if other OSs did this. I've been using my current OS for a few years now because it has high idle enabled.
  1. {D2216} TTC Lock Up Pressure Ramp function
    By Redline Motorsports in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: July 24th, 2020, 09:12 AM
  2. Help with rail pressure
    By catman3126 in forum Cummins 5.9L
    Last Post: May 13th, 2015, 05:22 AM
  3. LMM rail pressure
    By DuramaxPowered in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 1st, 2012, 05:36 PM
  4. Rail Pressure
    By mstordahl in forum Cummins 5.9L
    Last Post: June 11th, 2012, 11:27 PM
  5. Rail Pressure tuning help?
    By AdamRRT in forum Cummins 5.9L
    Last Post: October 24th, 2011, 01:00 PM
