Results 1 to 4 of 4
Thread: No Fuel Pressure Reading
    Jun 2009
    Default No Fuel Pressure Reading
    Ok, so its has been a long while since I have used EFIlive to tune on my camaro. I spun a bearing on it a few years ago and I am just now getting it back up and running. With the built motor i'm getting the idle dialed in etc...
    there have been several software upgrades and firmware upgrades on the v2.
    My issues is I had wired up a fuel pressure sensor into the V2. However, it isn't reading fuel pressure. I tested and am getting the correct 2.5volts. Is there anything else i need to do? was something maybe lost in the firmware upgrade. I briefly scanned over the old tutorial on how to set it up but nothing stood out that i have wrong. I am using the external 1 input, which looking at the face of the v2 is the furthest right ports.
    any suggestions, tips or tricks i need. I would like to log fuel pressure with this larger motor to make sure my pumps can keep up.
    What does DMM show when you measure voltage at the pressure sensor...?
    Post some pics of it and how it is wired.
    Jun 2009
    The wiring never changed, and is connected directly to the V2 (as i only use the fuel pressure sender for efiLive logging). I verified that I am getting approximately 2.5 volts to the v2. I was wondering if it was my calc.pid file, it looks okay to me but I have attached it.
    could it be something on the V2 itself is now not working properly? would there be a way to test?
    Disconnect the signal wire from FSV2, and use a DMM to measure what voltage the fuel pressure sender is outputing.
  1. can I log fuel pressure with my glowShift fuel pressure gauge?
    By ryans1000 in forum External A/D inputs
    Last Post: August 16th, 2011, 01:35 AM
  2. Fuel Rail Pressure's relationship to fuel economy.
    By duramaximizer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 28th, 2010, 01:18 PM
  3. Reading oil pressure and fuel temp on a LBZ
    By Jasondt2001 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 11th, 2008, 09:29 PM
  4. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
  5. Fuel Pressure.
    By 06bowtie_guy in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 24th, 2007, 06:37 AM
