Results 1 to 10 of 13
Thread: Unable to Edit Trans Diag, Fuel Sys, System, Speedo
    Mar 2009
    Default Unable to Edit Trans Diag, Fuel Sys, System, Speedo
    Like the title says on 1 particular vehicle suddenly none of the tunes will allow me to edit the trans diagnostics, fuel system, system, or speedo. All other vehicles will expand these menus and allow me to make changes. I have made changes to these tables in the past, so I'm baffled as to why I can't now. Any ideas? My software is old as hell but I don't see that being a factor here. I've attached an image for reference.
    Post your tune file (or email it to me)(pm me for email address).
    Mar 2009
    Derr. Here's what it's running now, don't judge.
    411 Whipple V19 Misfire Detection Disable.tun
    Not sure what the issue could be but I see all segments when I open the file - latest public release.
    Mar 2009
    GMPX is the dropdown arrow there for the segments in question?
    Sure is.
    I opened your tune file, all segments show up and expand ok for me.
    Do you maybe have a .cax file loaded that might be causing problems somehow?
    Mar 2009
    Hmm, I'll have to dig into that. No recent changes to my cax situation. You know what I did do though was dump a calz in from a newer software version. It gave me access to transient fueling, but now I wonder if it isn't screwing with the other segments in question.
    Mar 2009
    Switched back to original .calz file, no dice. Also created an archive folder in my CAX folder and dumped everything into that and same deal. Is there a repository of old software versions somewhere? My laptop is running V7.5.5 but my desktop ran something a touch newer that was compatible. Unfortunately that HDD took a dump and I don't even know what version it was.
  1. How do I properly setup the speedo for a manual trans E67?
    By 04colyZQ8 in forum E37, E38 & E67 PFI ECM's
    Last Post: January 15th, 2017, 11:05 AM
  2. Returnless fuel system
    By sparkinak in forum Gen III V8 Specific
    Last Post: August 17th, 2016, 07:32 AM
  3. problem system to lean '02 Trans Am
    By gcross in forum Gen III V8 Specific
    Last Post: May 31st, 2009, 09:47 AM
  4. 98 to 99+ fuel system segment swap.
    By waterbug1999 in forum Gen III V8 Specific
    Last Post: October 8th, 2008, 09:21 AM
  5. Question on Fuel System
    By Randy07GMAX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 17th, 2008, 06:13 PM
