Results 1 to 4 of 4
Thread: AC compressor not running at idle
    Jun 2009
    Default AC compressor not running at idle
    Coincidence or tune?
    2000 Yukon XL with transplant 6.0L…
    AC worked fine before and after engine swap.
    E-fans installed long before engine swap and working fine also, both speeds.
    AC pressures good, pressure switches checked.
    Condenser not blocked.
    Multiple tune iterations later, while working on idle quality, at some point the AC compressor stopped working at low RPM/idle. It takes about 1500 RPM to get compressor to kick on.
    Figured it was a tired old compressor so I replaced with new Denso unit followed by vacuum and charge with correct amount (by weight) of R134a. Same problem continues. AC works great when compressor operates, even before compressor change.
    Is it possible that there is a (for lack of better term) glitch associated with tuning?
    Jun 2009
    Fix was programming B4522 Stall Saver RPM back to stock-like buffer between desired idle and stall saver RPM. Apparently inadvertent activation of stall saver will shut off A/C compressor?
    Feb 2006
    Thanks for the update
    Thanks.
  1. Rich Idle with fan running lean with out
    By kostelacd69 in forum Gen III V8 Specific
    Last Post: June 22nd, 2017, 03:00 PM
  2. ID1000 are running rich at idle
    By Brad Kimbler in forum Gen III V8 Specific
    Last Post: November 10th, 2014, 01:16 AM
  3. Running Lean at Idle
    By mikeyayell in forum Gen III V8 Specific
    Last Post: December 28th, 2007, 07:55 AM
  4. Car Running lean during idle and cruise under 2k
    By Joel_SS in forum General (Petrol, Gas, Ethanol)
    Last Post: July 13th, 2006, 05:49 AM
  5. running rish at idle
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 20th, 2006, 05:37 PM
