Results 11 to 20 of 24
Thread: Current Public Release (Oct 2018)
    Feb 2016
    Default Error code 1400
    Getting this error all of a sudden. It was working fine and then I opened a tune today and another using the open to compare function. Updated a few tables in the first tune using update function and now I get this message whenever I try to close 7.5.
Name:	New Error.JPG
    Quote Originally Posted by Bdirtymax View Post
    Try deleting the V7 registry hive. You can do that by:
    Close all EFILive software.
    Run "Regedit".
    Locate the key: \\HKEY_CURRENT_USER\Software\EFILive\V7.5
    Delete the V7.5 entry and all subkeys
    Close Regedit.
    Restart V7 Tune tool - this will recreate the registry entries with their original default values.
    WARNING: That will revert all your EFILive software settings (such as colors, windows sizes, recently used folder names etc), back to installation defaults.
    However, it is possible that one or more settings are faulty/damaged and could be causing the problem.
    Feb 2016
    Run "Regedit".
    Close Regedit.
    Paul,
    Did as you described. Still getting the same error. I opened a tune and then closed 7.5 and that window pops up. I haven't had any issues with it since the update until I performed the compare and update on a tune today.
    Edit the shortcut (right click, select Properties) and add " /l" (that's space, forward slash, lowercase L, without the quotes) to the "Target" field, like this:
    That will turn on startup/shutdown logging for the V7 software. A trace file called "StartupLog.txt" will be generated in the V7 install folder, usually: \Program Files (x86)\EFILive\V7.5.
    You will need to run the altered shortcut using right-click "Run as administrator" to allow the EFILive software to create/write the trace file in the "program files (x86)" folder hierarchy.
    After you get the error, send the StartupLog.txt trace file me at paul@efilive.com
    Feb 2016
    Log file sent. Thanks
    Nothing appears wrong in the log file - everything checks out OK.
    The only other option I can suggest is to uninstall/reinstall the V7.5 software.
    After uninstalling, I recommend deleting the \Program Files (x86)\EFILive\V7.5 folder before reinstalling. That will ensure no old/damaged files are left hanging around that may interfere with the new install.
    Feb 2016
    I'll give that a shot.
    Jul 2003
    I have that same issue too....
  9. #19
    Feb 2016
    I've tried uninstalling it, deleting the folder as well as the registry then re-started the computer and downloaded and installed 7.5 again. Still get the same error. Sent another log file in case something showed up this time.
  10. #20
    May 2014
    Possible bug report.
    V8 Scan and Tune program
    F5: BBX->F2: Scan
    First time I have this page up, the 'function viewer' for calculated PIDs works fine. If I close the BBX window and return to the main program screen and then re-open F5:BBX, then the function viewer does not work and I get an access violation. If I restart the program, function viewer again functions the first time I open up the F5:BBX window. I get a slightly different error depending on if the V2 is connected or not.
  1. Current Public Release (Sep 2018)
    Last Post: October 30th, 2018, 03:59 AM
  2. Current Public Release (May 2018)
    Last Post: July 5th, 2018, 11:36 AM
  3. Public Release (Updated Oct 31, 2017)
    Last Post: November 1st, 2017, 09:30 AM
  4. Current Public Release (Oct 2017)
    Last Post: October 25th, 2017, 04:55 PM
  5. Oct 2017, Release Candidate 4 (AKA Public Release)
    Last Post: October 23rd, 2017, 09:17 AM
