Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Current Public Release (Oct 2018)
    Default Current Public Release (Oct 2018)
    Release Notes:
    Version Numbers:
    After installing this beta release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.25 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.21 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.008 (Jul 4, 2018) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.138 (Oct 25, 2018) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Download here:
    Known Issues:
    Issue #1:
    Workaround:
    None.
    Issue #2:
    Workaround:
    Lifetime Member Road's Avatar
    Feb 2015
    While greatly appreciate the few 2018 csp operating systems that have been added but are you going to add in 2016 and 2017 OS that have been over looked?
    Hi Mike, there should be 2016 & 2017 in there too, I can see the .calz files:
    52160202 (original 32160202)
    52170403 (original 32170403)
    52170404 (original 32170404)
    Dec 2014
    Getting this now on windows 10. Tried running as admin
    Quote Originally Posted by Team208Motorsports View Post
    You need to give Windows 10 permission to write/update files in the C:\Program Files (x86)\EFILive\V7.5\Configuration folder. To do that:
    1. Open Windows Explorer.
    2. Navigate to C:\Program Files (x86)\EFILive\V7.5\Configuration.
    3. Right click on the "Configuration" folder name and select "Properties".
    4. Select the [Security] tab page.
    5. Click on the [Edit] button.
    6. Click the [Add] button.
    7. Type in your Windows username (if you don't know your Windows user name, click [Advanced], then [Find now] and select your username from the list and click [OK]).
    8. Click [Check Names] to make sure the name you entered is valid (it may change to prefix your computer name to the username).
    9. Click [OK].
    10. Make sure the newly added username is selected in the list and check/activate the "Full control/Allow" check box.
    11. Click [OK].
    12. Click [OK].
    Dec 2014
    Thanks!!!
    Apr 2008
    V7.5 & V8 unusable after this update. Tried above instructions, did not help. Tried uninstalling and deleting program files and then fresh install. This did not help either still getting same errors. Cant close program endless errors keep popping up.
ID:	22510Click image for larger version.
    For V7.5 issues:
    To completely reset V7.5 to factory/install defaults, close all EFILive V7.5 software, uninstall, run "regedit" and remove the entire V7 registry hive from here: Computer\HKEY_CURRENT_USER\Software\EFILive\V7.5 then re-install.
    You could try modifying the V7 Tune Tool desktop icon (right click and select properties) so that the "Target" field has a " /l" at the end. (that's space, forward slash, lower-case L, without the quotes).
    Then run the tune tool "as administrator" by right clicking on the icon and selecting "Run as Administrator", that will create a StartupLog.txt file in the \Program Files (x86)\EFILive\V7.5 folder.
    like this:
    Try looking in that trace file to see if it shows any issues.
    For V8 issues:
    To completely reset V8 to factory/install defaults, close all EFILive V8 software, uninstall, delete the V8 install folder: \Program Files (x86)\EFILive\V8
    and delete the three files:
    Documents\EFILive\V8\Config\EFILiveScanAndTuneLayo ut.ini
    Documents\EFILive\V8\Config\EFILiveHapi.ini
    Documents\EFILive\V8\Config\EFILiveScanAndTune.ini
    Try starting the V8 software by double-clicking on the V8 Scan and Tune desktop icon while holding down the Ctrl key on the PC keyboard. That will create startup log file(s) in the folder: \Documents\EFILive\V8\Trace called
    EFILive_ScanAndTune_StartupLog.txt
    EFILive_Hapi_StartupLog.txt
    Try looking in those trace files to see if they show any issues.
    If those options don't help, please create a support ticket, as per these instructions: https://support.efilive.com/kb_artic...7778-QEKN-0400
    Apr 2008
    For V7.5 issues:
    like this:
    For V8 issues:
    Thanks for the tips but unfortunately that did not work. Will be creating a support ticket
    Apr 2008
    Sorry it was a computer issue. Tried to use anther tuning software and it was having errors as well. Just use that laptop for tuning so I did a reset and all is working well now. Not sure what the issue was just easier to reset and start over. Thanks for your quick response though.
  1. Current Public Release (Sep 2018)
    Last Post: October 30th, 2018, 03:59 AM
  2. Current Public Release (May 2018)
    Last Post: July 5th, 2018, 11:36 AM
  3. Public Release (Updated Oct 31, 2017)
    Last Post: November 1st, 2017, 09:30 AM
  4. Current Public Release (Oct 2017)
    Last Post: October 25th, 2017, 04:55 PM
  5. Oct 2017, Release Candidate 4 (AKA Public Release)
    Last Post: October 23rd, 2017, 09:17 AM
