Results 1 to 5 of 5
Thread: 6L80/90 T43 Tehcm - Command Solenoids.
    Nov 2018
    Cool 6L80/90 T43 Tehcm - Command Solenoids.
    Good Morning EFILive Team,
    I am in hopes that the engineering team has the possibility of adding a new feature. It would be great to able to command the individual solenoids (and/or the correct combination of said for a particular gear) on the 6L80/90 T43 Tehcm.. It would be a great addition to the Scan Tool as well to be able to 'hold' the trans in a particular gear / command TCC on and off.
    I am willing to test any Beta available with this feature. I have access to -many- different t43 Os Groups, but mainly Trucks (not only diesel applications). Thank you in advanced.
    Have you tried using the DVT (Dynamic Vehicle Testing) controls in the V7 scan tool?
    Or did you mean in the V8 scan tool? The V8 scan tool has not yet had the DVT controls added to it. That will happen in a future release of the V8 software.
    Nov 2018
    Sweet! Wow I feel stupid, I never actually opened Scan 7.5, only Scan 8.0 and Tune 7.5
    So what are the minimum controllers required to get this to work? BCM ECM and TCM? I have a ECM TCM set up with the Bench Force harness right now but when I click "activate" I get "Connect to Vehicle Prior to using the DVT Control Panel" error.
    In V7 scan you need to click on the "Connect" button to connect to a single controller (i.e. the TCM) prior to logging or using the DVT controls.
    Nov 2018
    Nevermind i was connecting to the FlashScan/AutoCal Only instead of connecting directly to the T43. Everything works!! Thank you Blacky.
  1. Command TCC with V2
    By l3elivE in forum Diesel
    Last Post: July 30th, 2015, 08:20 PM
  2. G8 Trans tuning (6L80 t43)
    By DDTECH in forum E37, E38 & E67 PFI ECM's
    Last Post: October 6th, 2013, 12:09 PM
  3. shift solenoids not working till commanded
    By SimpleManLance in forum Lounge
    Last Post: August 27th, 2011, 10:31 AM
  4. How many MM3's can you command?
    By LBZoom in forum Duramax LB7
    Last Post: February 2nd, 2010, 12:15 PM
  5. command vs actual a/f
    Last Post: June 9th, 2006, 01:50 AM
Tags for this Thread
