Results 1 to 9 of 9
Thread: Ram CM2350b 32381032sc o/s
    Jul 2012
    Default Ram CM2350b 32381032sc Cal ID
    I have a Cal ID on a 2013 Ram 3500 w/AISIN of 32381032SC which I believe uses a ECM code of DO90007. I have existing single and CSP tuning files that I use for DO90020 and DO90019 ECMs.
    Will I be able to use these or do I need to mod a stock DO90007 file with the calibration changes made from my existing DO90020 or 19?
    Long time since I've posted here...always learning from the fine folks on this forum.
    2006 Ford F250 Super Duty, 2008 Cummins 6.7, Allison 1000 5spd
    2011 Ford F250 Super Duty, 6.7L Scorpion
    Jul 2012
    Well, so far I see that comparing my tuned DO90020 cal to the DO090007 will not work due to using different O/S's. Therefore, my remaining question is simple...in theory, should my tuned DO90020 cal work on this truck that currently has a DO90007 Cal ID?
    The Cummins ECM code for 32381032SC is DO90007.22, you should only use another DO90007.xx as the DO90007 is the specific vehicle configuration base file, the .xx is the version of that calibration.
    Here's a few more so you can see the pattern between the Cummins calibration revisions and the Dodge CalID's:
    DO90007.15 = 32381032AQ
    DO90007.16 = 32381032AT
    DO90007.17 = 32381032AV
    DO90007.18 = 32381032AW
    DO90007.20 = 32381032SA
    DO90007.21 = 32381032SB
    DO90007.22 = 32381032SC
    DO90007.23 = 32381032SD
    DO90019.xx is for 68RFE vehicles.
    DO90020.xx is for Aisin but for 2015 models.
    Jul 2012
    Thanks for the quick reply Ross.
    I know that EFI Live will not allow for comparing tunes across different O/S's, but is there another way to move my DO90020 (6.7L/AISIN) tuning to a DO90007 ECM? Or just any other ideas that would prevent me from having to tune from base (binary in this case using 3rd party tools)?
    You can flash DO90020 over DO90007 if that is what is currently in the ECM, a reflash on a Cummins ECM wipes everything and transfers everything in the file to the ECM, that is just how they work.
    But I don't know what compatibility issues running 2015 software in a 2013 truck might cause with other modules on the vehicle.
    Jul 2012
    The existing OEM/dealer cal that is flashed to the ECM is a DO90007. I would like to flash a "tuned" DO90020 to is and overwrite the ECM.
    I edited my post after putting it up, it might make more sense now.
    Jul 2012
    Thanks Ross!
    Feb 2021
    Default Do90020.09
    Hi ! Im seeking for original cal. or bin files for RAM2500 6.7. Cummins Versions CM2350B official DO90020.09, CM2350B DO90020.06 32380532, CM2350B DO90019.09 32370531
    Appritiate in advance!
  1. CM2350B error $0312
    By modpcm in forum Cummins 6.7L
    Last Post: August 13th, 2018, 07:39 AM
  2. Cm2350b
    By Jstewy21 in forum Cummins 6.7L
    Last Post: July 15th, 2018, 01:05 PM
  3. CM2350B import
    By Red66 in forum Cummins 6.7L
    Last Post: February 9th, 2017, 11:09 AM
  4. CM2350B Run Modes
    By 30 RUM in forum Cummins 6.7L
    Last Post: November 22nd, 2016, 01:03 PM
  5. Cm2350b
    By catman3126 in forum Cummins 6.7L
    Last Post: January 14th, 2016, 03:50 AM
