Results 1 to 6 of 6
Thread: newbie with start issues 2000 vette
    Jun 2006
    Default newbie with start issues 2000 vette
    2K vette, A&A S/C, methanol injection, 42#, etc. Dyno tuned and LT trims are -2% across all cells. Car runs great, have installed WBO2 and AFR looks good also.
    Use to start up perfect when cold, stumble starting on hot days. Added check valve in methanol line to fix hot day start, but now all starts stumble to life - not a function of the check valve added. Had issues before check valve. Only starts fine after warm, and within 3 minutes of turning off.
    What parameters to scan, what to adjust, any help and advice would be appreciated. Remember, I am just getting started with EFILive. Have version 7, and can take logs, look at stuff, but really don't know what I am doing.
    TIA, Robi
    Aug 2005
    Could be that your FPR is leaking down pressure. If you turn the key to the on position a couple of times before actually starting it (to let the pump build up pressure) does it act any differently?
    Jun 2006
    I will give that a try. I do have a fuel pressure and boost gauges on the A pillar, and the FP is always between 52-57.
    Jun 2006
    Tried to power on/off a bunch to get FP up, but didn't help.
    BTW, does anybody know what and where the throttle opening parameter is for cold start and hot starts is?
    Oct 2005
    IAC Parked I believe
    You can also look at cranking VE, initial fuel prime, b4304 helped me a lot. After my cam starting was a nightmare, lots of cranking and I had to use the throttle. added air in to b4304 and it was fixed. Some of the other startup airflow tables might be useful too. Have a play in there.
    2014 VF SV LS3 Maloo.
    Jun 2006
    Thanks Ringram!! I will get into it later next week as it is the 4th of July weekend, and I'll be driving not tuning!!
  1. Hard start condition with 5.7 in 2000 S-10
    By lowriders10 in forum Vortec V6/V8 Specific
    Last Post: May 30th, 2010, 03:56 PM
  2. Help please 2000 vette with big cam
    By nchristian in forum Gen III V8 Specific
    Last Post: January 14th, 2010, 05:15 PM
  3. Looking for stock bin 2000 auto vette
    Last Post: September 27th, 2006, 02:55 PM
  4. 2000 gmc seirra 4.3 won't start after attempt to read pcm!!!
    By red12secz28 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 20th, 2005, 01:58 PM
  5. Newbie, 2000 to 2002 os,twin turbo,3 bar,low imp,I am lost!!
    Last Post: September 12th, 2005, 05:34 PM
