I've worked with a handful of e92/L83 swaps but this one is giving me issues. The only other 2017 I've touched used the stock fuel pump control module and fan control module, this one does not. I feel like I have it set up so that it will trigger a normal fuel pump relay (like I set up 2014 and 2015 ecms in the past) but for some reason is isn't. Is there a parameter in the background I am missing?
Also, this original drivetrain was 2wd, now a transfer case has been added turning it into 4x4. Is there some background parameters that can be changed to help with this? I am not getting a vss reading no matter what I do, the harness is wired like a 2017 4x4, but I have a feeling the tune is still looking for some internal info from the 2wd 6L80e. I don't see any further adjustments in the tune software for this.
It appears neither versions of the scan tool can do DVT functions with these ecms, correct? Or am I missing something? I'd really like to be able to turn the fans and fuel pump on if nothing else. This is set up for one discrete fan trigger, but I don't think that is working either.
Any help is appreciated. Thanks!
