Results 1 to 10 of 10
Thread: missing dtc enable/disable
    Jan 2007
    Default missing dtc enable/disable
    I must be missing something
    for this 2012 DOGE RAM 6.7L
    CM2200 Diesel Turbo
    OS 22120818
    CALIBRATION 12350331AN
    I cant find the dtc list, is it not there or am I just @#$@?
    and in case it matters I am not in the usa
    Nov 2010
    Pretty sure it doesn't exist period unless you cax it in. Regardless of your region
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Les is correct, no hidden options to enable anything they are simply not there across the board.
    Nov 2018
    So what does one do from here. these tuners arent cheap and we cant access the DTC's any tips on how I can access them by any means?
    Oct 2012
    Buy and learn CalTerm. You will also need a Peak Systems Cable.
    Buy CalTerm! I didn't know Cummins actually sold it to the public.
    Jan 2019
    This is crazy!! I was just asking same thing Are you guys going to offer this later is this in beta testing still? What’s going on.
    Senior Member KhakiCummins's Avatar
    Sep 2011
    EFILive has said that they WILL NOT be offering DTCs for any Cummins newer than 2009. This is nothing new, they have openly been saying this since 2012. I believe that they stopped offering then on GM diesels even before that.
    Duane
    2008 Ram 3500 QuadCab
    Hamilton 110# Springs & HD Pushrods, ARP 2000s, EFILive, SB 3250 DD
    Quote Originally Posted by Dan1stgen View Post
    It's just too hard to do now with the regulations in the USA (our biggest market), they will never be put in the software for any region. Majority of tuning software has taken the same path if they are selling in to the USA.
    Feb 2020
    I am in the same boat if have some information please share
  1. Idle spark enable/disable by VSS?
    By DrX in forum Gen III V8 Specific
    Last Post: July 25th, 2011, 02:19 PM
  2. Tweaking the 2010 camaro air conditioning enable/disable Parameters ?
    By 2010 Bumblebee in forum E37, E38 & E67 PFI ECM's
    Last Post: May 5th, 2010, 05:39 AM
  3. Disable DTC's
    By Pusher in forum Duramax LB7
    Last Post: April 2nd, 2008, 01:24 PM
  4. B4206 disable or enable during AutoVE tunning?
    Last Post: October 10th, 2007, 10:40 AM
  5. DTC code disable question
    By ScarabEpic22 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: April 23rd, 2007, 05:20 PM
