Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: How to set up RoadRunner with LC-2 Serial Widband
    Quote Originally Posted by Ponrov View Post
    Hi Joecar
    Thank you for your feedback
    LC-2 is connected with serial connection to V2
    LS1_Link
    ;Main VE Table
    B0101.ROW=SAE.RPM
    B0101.COL=SAE.MAP
    B0101.RRR=CALC.BEN1
    Have contact between V7 and RoadRunner, but do not get the same values in the V7Scan Vet Map as in RoadRunner B0101 , and the values in RTACS increases quickly to max limit .
    Has taken out the LC-2 wideband sensor and calibrate it, has also installed an additional Autometer wideband lambda to compare the values and test again. (have to wait for some nice weather outside).
    LC-2 in bank 1 and Autometer widband i bank 2
    Br Ponrov
    Post some screenshots so I can see what is happening...
    Apr 2014
    post someone after work today,
    97 Chevy RCSB 4WD, Internally stock 350 ,stock PCM, 4l60e, Bassani headers catback
    72 Firebird Formula ,engine 70mod 400 Ram air 3 ,0411 Road Runner PCM program Lextech, Lc-2 ,4l80e , axel9"wavetrack 3.91 ,Front rear brakes from gen5. Camaro,
    Apr 2014
    have only had the engine running have not driven it, tried on the last log (the picture are from) to switched from CALC.BEN1 to CALC.WO2BEN (same result).
Name:	LS_1Link 11.12.19. on.png
ID:	22560Click image for larger version.
Name:	only ign. on.png
ID:	22561Click image for larger version.
Name:	pids F8 11.12.19. on.png
ID:	22562Click image for larger version.
ID:	22563Click image for larger version.
Name:	Propeties display11.12.19. on.png
ID:	22564Click image for larger version.
Name:	Road Runner11.12.19. on.png
ID:	22565Click image for larger version.
Name:	scan test 11.12.19. on.png
ID:	22566Click image for larger version.
Name:	test 11.12.19. on.png
ID:	22567Click image for larger version.
Name:	Units 11.12.19. on.png
    Is your tune scaled for MAF or IFR...?
    What injectors do you have...?
    Apr 2014
    Is your tune scaled for MAF or IFR...? I dont know, where can i check it .
    MAF is 75 mm with std GM data
Name:	MAF tabele 12.12.19.png
    The injectors I use is ID850 Injector Dynamics , have used the data from link below with 58 psi fuel pressure
    http://injectordynamics.com/wp-conte...-3-23-2011.xls
  1. LC-1 widband hook up
    By ace68 in forum General
    Last Post: November 15th, 2016, 07:40 AM
  2. reduced engine power p1514 KOER set at idle but P1518 set KOEO
    By megadeus in forum Gen III V8 Specific
    Last Post: April 11th, 2015, 08:58 AM
  3. advice need wirth AEM widband
    By restless@westnet.com.au in forum General
    Last Post: April 3rd, 2013, 04:30 PM
  4. Quick question guys.....Roadrunner serial?
    By BSwope in forum Cummins 5.9L
    Last Post: January 29th, 2012, 07:02 AM
  5. Help, my PCM serial number was set to 000000000000
    Last Post: June 26th, 2009, 07:26 PM
