Results 1 to 4 of 4
Thread: Is there any way to log MAP values more than 255 kpa ?
    May 2010
    Default Is there any way to log MAP values more than 255 kpa ?
    Is there any way to log MAP values more than 255 kpa in LS1B ?
    Car has COS 5 and ZR1 map sensor and making 25 psi of boost so thats exceed tha MAP highest value in the scaner
    EFILive Tuner
    Wesam, because you are using an EFILive custom OS I think you can select 'GM.MAPBOOST_DMA', this should show you the actual boost figure.
    I apologise if I am giving you wrong information because it was a long time ago but that should show you MAP - BARO = GM.MAPBOOST_DMA, so you will end up with actual boost figures between 0 and 255 (which at sea level would be the equivalent MAP value of 100 - 355kPa).
    May 2010
    Thanks I will give it a try
    EFILive Tuner
    May 2014
    I'm on COS3 and GM.MAPBOOST_DMA just gave me zeros, for what it's worth.
  1. Please explain Delta MAP Kpa...
    By Redline Motorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: December 20th, 2019, 10:08 AM
  2. E67 B4001 chart scale kPa values?
    By ACCLR8N in forum E37, E38 & E67 PFI ECM's
    Last Post: February 2nd, 2018, 08:59 AM
  3. 3Bar for 03 Suburban file, MAP scanner values are stuck at 105 kpa
    By gm22j in forum Custom Operating Systems
    Last Post: August 7th, 2017, 08:24 AM
  4. maxing out map sensor @255 KPA- power reduction
    By rubbersidedown in forum Gen III V8 Specific
    Last Post: October 1st, 2007, 10:48 AM
  5. WOT MAP Values(kPa)
    By Black02SS in forum General (Petrol, Gas, Ethanol)
    Last Post: July 16th, 2005, 02:34 PM
