Page 4 of 11 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 106
Thread: Throttle Cracker Tuning Question {B4309}
  1. #31
    Aug 2016
    I don't have an issue changing my MAF sensor. I do have a Delphi part number 25168491 black 85mm MAF I can put in, I have the adapter harness for it as well. We should be able to use it with the MAF curve out of an 2001 Suburban with the 5.3 right?
    If I make that hardware change, I have a set of D585 coils I'd like to put on as well. I've been putting off installing both parts, so this may be a good break to put them on. These should need the spark dwell table out of a Yukon with the gen. III 6.0.
    In the interim, I'll flash your Mod5 tune and get a log. Is it still helpful when I list portions of the tune with/without bucking?
  2. #32
    Aug 2013
    Yes, listing where it's bucking is still helpful... but make ALL the hardware changes you want to make now, then do a log for me. Use the 2001 Suburban MAF curve, even if it shows lots of trims (as long as it doesn't peg the trims) and use the Yukon spark dwell table for the new coils. Just apply those changes to the Mod5 tune and remember not to drive on the Mod4 tune anymore.
  3. #33
    Aug 2013
    When you post your next log, also post the tune file with all the changes you made.
  4. #34
    Aug 2016
    Got it! I ran back through my log, it goes wicked lean in PE with Mod4! I'll get this flashed before I go for another drive.
    I'll post the tune with the log as well. I try to keep a tune history in my comments, with each of your Mods I've transferred your changed tables and written the changes in my history. Helps me keep track of things.
  5. #35
    Write long post separately in Nodepad first, then paste to reply.
    I've been out of town for a few days, I'm slowly catching up.
  6. #36
    Aug 2016
    Alright I made the changes, did some logging and updated my MAF table. Overall I'm pretty pleased with the results, the car seems to turn on better and drive more smoothly. The MAF table looks like a normal MAF table, too. I Included your Mod5 updates, Statesman, updated the spark dwell table for the D585 coils, and got the MAF table in a pretty good spot. I still have bucking below 1200RPM off throttle, and sometimes at low throttle inputs. I've included the updated tune and the latest log. Below are some roadmap notes for the tune. ECT hits 80C around frame 1290, have a look at IATs for a laugh.
    Steady throttle crusing:
    Frames 1325-1679
    Frames 3321-3707
    High throttle acceleration:
    Frames 1801-1892
    Bucking with throttle input:
    Frames 2420-2607
    Frames 3834-3867
    Frames 4575-4630
    Frames 4954-5217
    Frames 7586-7686 (pretty bad here)
    Bucking during deceleration:
    Frames 1917-2139
    Frames 2316-2360
    Frames 4642-4714
    Frames 6738-6769
    Frames 10,405-10,465
    Let me know what you think, replacing the MAF sensor seemed like a good call, I'm glad I had that Delphi unit sitting around.
    Tune:
    Garrett_GTO_tuned_20190125_2.ctz
    Log:
    GTO Jan 30 2019 IBC to home.efi
  7. #37
    Aug 2013
    I just had a quick look at your log and yeah, your IATs are impressive. I also noticed your engine take a dump towards the end of the log... I'll have to take a closer look at what happened there. I don't have the time right now to run your numbers, but I 'll try to have something for you this weekend.
  8. #38
    Aug 2016
    Yep sounds good! Are you seeing the dump around frame 13,400? It does that periodically, especially with the headlights on. That should have been when I pulled into my driveway and garage. It does that in low speed situations like parking lots occasionally.
  9. #39
    Aug 2013
    Quote Originally Posted by pinstripebob View Post
    Yeah, this Delphi unit is performing much better. Your fueling already looks reasonable, but I need it a bit closer.
    When you flash in this update, I'd like you to also clear your trims.
  10. #40
    Aug 2016
    This last week has been really busy for me, but I flashed your Mod6 and got a good log. I made sure to get up to operating temp, reset the fuel trims, then start the log and start driving. Overall the car is noticeably better under low RPM/low TPS driving, definitely less bucking. It does a better job under "parking lot" conditions, RPM doesn't drop and swing as much.
    There was something weird, AFR went lean for a bit. It seemed to go lean after a higher TPS/RPM pull around frame 2,550, very odd. Restarting the engine/widebanad seemed to fix the wideband's readings though.
    ECT for the log hits 80C around frame 440. Below are the trouble spots I noticed:
    Low TPS bucking:
    Frames 1,078-1,126
    Frames 1,330-1,368
    Frames 2,048-2,080
    Frames 3,079-3,321
    Frames 4,432-4,525
    Frames 4,815-4,875
    Frames 4,918-4,973
    Frames 5,263-5,395 (pretty bad here)
    Frames 5,621-5,717 (bad here as well)
    Frames 9,661-9.721
    Frames 10,223-10,247
    Bucking while decelerating:
    Frames 1,729-1,751
    Frames 2,180-2,202
    Frames 3,480-3,507
    Frames 8,332-8,349
    Frames 8,373-8,384
    Frames 8,456-8,481
    Frames 8,863-8,907
    Frames 8,951-8,993
    Frames 10,254-10,277
    Frames 10,966-11,007 (bucking got worse as it dropped RPM)
    Let me know what you think. Again, I appreciate the help, thank you!
    Log:
    GTO Feb 7 2019 IBC to home.efi
  1. Throttle follower/ cracker question
    By fatelvis7 in forum Gen III V8 Specific
    Last Post: August 1st, 2011, 06:23 AM
  2. Throttle cracker question
    By samh_08 in forum Gen III V8 Specific
    Last Post: May 6th, 2009, 04:26 PM
  3. Can B4309 (Throttle Cracker) tuned/adjusted using RAFIG PIDs?
    By BlackGMC in forum Gen III V8 Specific
    Last Post: August 13th, 2008, 09:24 AM
  4. Quick Question about how throttle cracker effects AutoVE
    By Kevin Doe in forum General (Petrol, Gas, Ethanol)
    Last Post: October 30th, 2007, 12:56 AM
  5. Throttle Cracker question
    By DaddySS in forum Gen III V8 Specific
    Last Post: September 2nd, 2007, 05:10 AM
