Results 1 to 3 of 3
Thread: Flash-scan LS1B connection problems but e38 is fine???
    Senior Member auspeed's Avatar
    Jul 2010
    Default Flash-scan LS1B connection problems but e38 is fine???
    Hi Guys,
    For some reason of late i have been having issues with not detecting LS1B pcms i have to re-power the flashscan v2 3-4 times and restart the software to get it to connect intermittently.
    However when connecting to e38 pcms it never has an issue and always works. (Which I assume means the cables are fine)
    Any thoughts here?
    When you connect FlashScan to the vehicle (with no PC USB connection) does FlashScan show "VPW-xx" on the lower right corner of the display (where xx is the number of VPW controllers detected)?
    That lets you know that FlashScan was able to detect one or more VPW controllers - even if it can't actually identify the controller as an LS1B. To specifically identify an LS1B controller FlashScan requests some information from the PCM and then attempts to match that info known about LS1B controllers.
    Just trying to figure out if the problem is with detecting any type of VPW controller - or just LSB1 Controllers.
    Jul 2010
    Comes up with S-VPW-01 on the screen
  1. flash scan v2 problems
    By tcole in forum General
    Last Post: May 10th, 2018, 04:29 AM
  2. Flash Scan V1.2 / E38 ECM?
    By vortecyota in forum E37, E38 & E67 PFI ECM's
    Last Post: March 3rd, 2014, 01:43 PM
  3. HELP, can't flash LS1B after E38 licence
    By O1Z06 in forum FlashScan V2
    Last Post: January 8th, 2013, 04:21 PM
  4. Flash Scan box to usb cable connection problems
    By cmitchell17 in forum FlashScan V1
    Last Post: July 3rd, 2009, 04:17 AM
  5. Flash Scan V2 problems
    By loafycleetus in forum FlashScan V2
    Last Post: April 20th, 2009, 02:51 AM
