Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Tony Bushman you do not accept PMs.
    Nov 2015
    I'll try this one more time. The dang forum keeps cutting off my replys for some reason. What I was saying is your leaving a lot of efficiency and power on the table with your timing that low. If the timing is right it will have a little rattle to it. The best way I think though is to keep the pilot from idle to about 1000 rpm so it is quiet when your idling in drive thru etc. Then go to single event tune afterwards if you want. I ran a tune like that for a while and then changed it to keep pilot until around 2500 rpm and cut off because my wife said it was too loud when she drove it with the old tune lol. That's atleaset how I do it and what I think. You will probably get tons of different opinions on this. I came from p7100s and vp trucks to the CR truck so running timing or having rattle was all normal for me. Sometimes it seems like if all you've ever known is just a CR truck with pilot the minute you hear the rattle it freaks you out.
    Dec 2018
    Quote Originally Posted by Ghostman View Post
    I like the sound of the single event. I think it sounds like the 12 valves and 2nd gen trucks. What can I do about the timing to get it where I need it. I dont really know how to make a timing table. What timing should I start with and what do I look for when adjusting at idle and at rpm?
    Dec 2018
    I like the sound of the tune and I am really just playing around with it. What would you say the best way to time it properly. Just advance it until it sounds right and go from there?
    Nov 2015
    Default Tony Bushman you do not accept PMs.
    Stupid forum
    Nov 2015
    Let me try this again
    Nov 2015
    Tapatalk isn
    Dec 2018
    Tapatalk isn
    What would you do then. I need help with this I dont know what to do and my biggest question is timing!
  1. Replies: 13
    Last Post: July 3rd, 2014, 12:52 PM
  2. 04.5 LLY wont accept DSP5 tunes or data log
    By TRUBBS in forum Duramax LLY
    Last Post: July 26th, 2013, 09:56 AM
  3. RR won't accept any tune from EFILive but fine from Tunercat and EMUtility
    By N0DIH in forum RoadRunner Real-Time PCM Emulator
    Last Post: November 23rd, 2011, 08:17 PM
