Results 1 to 8 of 8
Thread: Locking and unlocking converter in 3rd gear
    New Member Scott(382-$T$)'s Avatar
    Default Locking and unlocking converter in 3rd gear
    I have tried several times to get my converter to unlock under part throttle.
    No matter what i have tried for settings, the converter will not unlock under
    part throttle. I am wanting to cruise around town in 3rd with the converter
    locked. Then while locked i want it to release under part throttle. Right now
    it will only unlock under full throttle. Any help would greatly be appreciated.
    382 stroker STS turbo-Callies,Compstar,Diamond,
    FAST,NW,TEA,232-240 595-608 lift,Moser 3:73,
    FMIC,RPM trans,ect.......... a special thanks to
    BOB,CHIP,and BRENT @ EPP
    Jun 2006
    You tried D1008 - TCC Throttle Release ?
    Hypocrits make terrible world leaders
    1999 GMC 1500 RC SB 5.3 4L60E (1 rebuild)
    Trans-go shift, DJM 2-4, Hotchkis frt&rr
    Yup sure did
    Sep 2005
    Conditions have to be meet in both D1005 Release speed (above set speed/ tps postion) and D1008 Throttle release for the converter to unlock at part throttle. Mine is setup not to unlock till 100% tps in third, but I have set it up to release in forth shortly before a down shift is called for at high way speeds.
    Lifetime Member emarkay's Avatar
    Is the stock converter clutch designed for this? (I really have no idea.) Wondering if holding it engaged longer and under more load at release will either prematurely wear it, or cause a destructive failure? Also, isn't torque management being applied under a WOT unlock?
    Early EFILive V5 user - Upgraded from AutoTap for DOS!
    2000 Chevrolet Camaro Z28, A4 - For occasional day trips...
    1984 Chevrolet Caprice Classic - For the family...
    1989 Honda VTR250 - For me and me only...
    Aug 2005
    Quote Originally Posted by kbracing96
    Are you sure it is both and not one or the other?
    My truck has throttle release set to 100% across the board for 2nd, 3rd and 4th from the factory, but that doesn't stop it from unlocking via the release speed table...
    Sep 2005
    Humm... Maybe it is one or the other. I was trying to get my truck to unlock in 4th on the interstate before the down shift, and it wouldn't do it with just lowering D1009 tps setting untill I lowered the speed setting in D1006. I thought it had to be both settings... maybe I was wrong.
    Aug 2005
    Maybe the release throttle doesn't work with our trucks. I have only been using the speed release. Going to try the throttle release table tomorrow. I want my converter to unlock at the point that I go into boost below 2400rpms.
  1. Locking converter in 2nd gear...
    By LS1_Dragster in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 25th, 2009, 11:38 PM
  2. converter locking in 2nd & 3rd @ WOT
    By Superado in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 31st, 2009, 08:27 AM
  3. locking/unlocking issues
    Last Post: July 13th, 2009, 12:32 PM
  4. Unlocking PCM
    By mjp80538 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 16th, 2006, 02:56 PM
  5. Pcm Unlocking
    By JCA in forum Tips and tricks
    Last Post: October 19th, 2006, 03:22 AM
