Results 1 to 8 of 8
Thread: 01290005 custom operating system
    Oct 2007
    Default 01290005 custom operating system
    I have a 2004 lS1 Holden manual 12225074 using 7.5 software and want to upgrade to 01290005 operating system where can I find the operating system to load into the PCM with 7.5.
    Found the operating system under EFILive. V7.5 >calibrations>LS1B> Custom, however it will not open, says "File type not supported."
    Which V7 software version/build are you using...?
    Oct 2007
    Joecar thanks for the prompt response. The version I am using is V7-5-7 build 299 which works fine with an existing 01290005 auto tune however I now need to set up a manual tune.
    Let me try this on my PC (when I get home tomorrow).
    Oct 2007
    OK thank you.
    May 2008
    \Documents\EFILive\V7.5\Bins\Custom OS
    Quote Originally Posted by GMTECH4 View Post
    Yortt: ^ this is where you should be loading the COS file from.
    Note: calibration/tune files are either .ctz or .tun and not .calz.
    GMTECH4: thanks.
    Oct 2007
    GMTECH4: thanks.
    GMTECH4 and Joecar got it thank you both, works fine when you look in the correct place.
  1. custom operating system files
    By wyochimneysweep in forum Custom Operating Systems
    Last Post: August 17th, 2015, 01:26 PM
  2. Custom operating system
    By Harrismarine in forum Custom Operating Systems
    Last Post: October 16th, 2009, 04:02 AM
  3. Why run a Custom Operating System???
    By RacerChris in forum Custom Operating Systems
    Last Post: November 11th, 2008, 10:45 AM
  4. 98 Custom operating system...
    By 98SS2836 in forum Custom Operating Systems
    Last Post: March 19th, 2007, 10:44 AM
