Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: torque managment
    May 2016
    Default torque managment
    Hello can someone point me in the right direction for torque management cm2350 ? working with file DO90008.08. The truck runs better with some adjustments but still cant even spin the tires. I'm not looking to brake the truck in half but a little giddy up below 1600rpm would be nice. I tried disabling limiters in D2019 and then I tried increasing rpm in all tables in rpm limiter torque adjust. Im not able to log data with efi so on my scanner when I try a boosted launch it will command around 350lb tq and mode switches to other and it flattens out. Can someone lend me a hand? regards 26sutphen....
    Nov 2010
    Deleted or emissions equipped tuning?
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    May 2016
    everything is still in place. Thank you for the prompt reply
    Nov 2010
    Have you modified the Trans parameters to remove torque management?
    Les Szmidt
    2007 5.9 Dodge Ram
    May 2016
    I have not, I looked through the parameters but didn't see anything for torque management.
    Nov 2010
    There are some in there, and are you turning off your traction control on the dash?
    Les Szmidt
    2007 5.9 Dodge Ram
    May 2016
    can you point me to the limiters for the trans? and I haven't disabled the traction control. Duh on my part. but the tires don't even slip and activate it. Also when driving and doing a roll on its just real soft down low.
    Nov 2010
    You need to actually add power down low along with raising limiters and traction control deactivation. Pedal table, torque to fuel tables, pulse table etc
    Just turning or raising torque values without adding power won't spin the tires.
    Les Szmidt
    2007 5.9 Dodge Ram
    Nov 2010
    You do need to be careful with how much torque you add...the emissions system will begin to get irritated and will give you issues if you push too hard down low.
    Do you have a way to monitor dpf pressure delta and if it's regenerating or not?
    Les Szmidt
    2007 5.9 Dodge Ram
    May 2016
    Ok, Kinda what I did. On the pedal map I requested more torque. Then I went to torque limiters and made sure what I requested was was that or greater. Then I looked at the torque to fuel and made sure at a given torque the fuel was atleast that or more in the main limiters. it seems to have woken the truck up but still nothing down low...I know im missing something that's why im asking for some help. and thank you for the replies
  1. Active Fuel Managment in a 2011 Camaro L99?
    By BowlingSS in forum E37, E38 & E67 PFI ECM's
    Last Post: December 11th, 2010, 07:49 AM
  2. Active Fuel Managment Strategies?
    By JAY4SPEED in forum Tuning For Economy
    Last Post: November 7th, 2009, 05:38 PM
  3. Torque management, TCS, TCS fast torque loss
    By AGRO in forum General (Petrol, Gas, Ethanol)
    Last Post: October 2nd, 2006, 05:16 AM
  4. More torque
    By purrvert in forum General
    Last Post: June 22nd, 2006, 03:28 PM
  5. step by step torque managment,speed limiter,efan,engine torq
    By 5.3 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 24th, 2005, 11:12 PM
