Results 1 to 3 of 3
Thread: Throttle response
    Jul 2018
    Default Throttle response
    What is the best way to increase throttle response with tuning? Tired of sluggish take off. 2014 2500 auto had emissions intact
    Jan 2019
    Granted I'm new to this but if you're talking pedal response in general then pedal to torque curves. You can add more columns and make more aggressive. I did just the opposite with my manual tune. I changed columns to 0, 50, 90, 100% and added all of the torque increase at the 100% column to make my pedal response feel like factory down low through 90%.
    If you're looking for better response when you floor it period, then you're talking about spool time: then smaller turbo OR more fuel which taken to the limit results in black smoke which can be compensated for with nitrous.
    2017 2500 CC 6-sp 4WD RIP: 98.5 F250 7.3 6-sp, 2006 Duramax 6-sp
    Jul 2018
    I will try that and see
  1. ETC Throttle Response
    Last Post: April 13th, 2015, 04:39 AM
  2. DBW Throttle response
    By dazzak75 in forum Petrol / Gas
    Last Post: December 1st, 2012, 05:36 PM
  3. Throttle response
    By catman3126 in forum Duramax LLY
    Last Post: July 11th, 2011, 02:27 PM
  4. dead throttle response
    By farmer79 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 20th, 2008, 02:02 PM
  5. Better Throttle Response
    By dirt_track_racer_81 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 8th, 2006, 02:43 PM
