Results 1 to 2 of 2
Thread: Please HELP, LMM ECM Issue
    Jan 2019
    Default Please HELP, LMM ECM Issue
    Im in desperate need of help, when installing my DSP5 switch I accidentally put the pins in 45 and 54 instead of 46 and 54. I cycled the switch and it started throwing a bunch of codes. Now my ECM is not communicating properly and a shop says its fried. By doing this did I fry my ECM or was it something on the tune? I just dont want to put in a new ECM and go to tune it and fry it again. As I was going through codes I noticed injector 5 balance rate was over a volt off the others and over a volt different than the last time i checked balance rates. I looked up Pin 45 to see where it goes and sure enough it is to injector 5. May I have also damaged my #5 injector?
    Jan 2006
    If you reload a stock tune, you may have your answer.
    Also log your dsp voltage, as long as it is showing 5 values that make sense, you should be ok with another ecm.
    Custom Tuning Services
  1. LMM Fuel Pressure issue
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 25th, 2011, 07:14 AM
  2. Need LBZ ecm, willing to give immacculate LMM ecm as exchange
    By badassmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 9th, 2011, 04:20 AM
  3. Lmm dsp5 issue!
    By cumminsDK in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 7th, 2010, 11:47 AM
  4. LMM Boost Issue
    By DmaxKid in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 9th, 2009, 03:38 AM
  5. LBZ / LMM Build77 issue
    By GMPX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 8th, 2009, 12:11 PM
