Results 21 to 30 of 43
Thread: Current Public Release (Updated - Feb 2019)
  1. #21
    So made it a little further. The PIDS compile. When I try to validate them, it seems to be pulling the Speedo System Segment # as the OS #?
    Not trying to be a pain in the ass.... Just pushing extra buttons today i guess.
    Attachment 22615
    Turns out the E86A.pmm file is mis-configured to retrieve the OS using $1A,$C2 (which is the speedo segment). E86B suffers the same problem.
    I've attached updated *.pmm files to correct the problem.
    E86_OS_Validation_Fix.zip
    Download and unzip the two files into the folder: \Program Files (x86)\EFILive\V8\Config
    Note: The 12641475 speedo number can be manually removed from the drop down list by editing the file: \Documents\EFILive\V8\Config\PIDs\E86A.pxl
  2. #22
    May 2014
    The CALC. prefix is reserved for EFILive defined calculated PIDs so that user changes are not overwritten by the next update - which always replaces/overwrites the files containing the EFILive calculated PIDs.
    Any reason why you must use the CALC. prefix? What's wrong with using some other prefix?
    Paul, I think I found my fix. For some reason I had it in my head that V7 calculated PIDs had to have a CALC prefix (probably from following the various guides on here and PDFs, I think they all use CALC). But I think the easy fix for me is to just name all of my calculated PIDs with the USER (or whatever) prefix in calc_pids.txt and that will ensure V7/V8 software is on the same page. V7 scan software doesn't seem to acknowledge any custom defined params other than CALC as (calculated), but that's no biggie.
    Thanks for the reply.
  3. #23
    Dec 2012
    Sweet! Thankyou Very Much! Closer! haha Next issue seems to be that it is still handling the address as 24bit. I saw your warning as you stated above...
    Code:
    ; NOTE:
    ; Some controllers use 32 bits for DMA addresses, EFILive only allows 24 bit addresses to be specified in this file.
    ; EFILive automatically adds the most significant byte as follows:
    ;  - For E39, E39A, E78, E92, E98, E80, E81, E82, E84, T87, E83A and E83B EFILive ORs the DMA address provided with 0x40000000
    ;  - For E20 and E40 EFILive ORs the DMA address provided with 0xFF000000
    If it helps any, here is V8 calling for the DMA. It looks to be missing the $DO Hi-Byte.
    And here is the pid being called with Mode $23 manually, granted it isnt 100% the same as the Mode $2D, $2C, $2A combo, but it should show what Im talking about.
    Josh
    '04 GMC LLY
  4. #24
    Code:
    ; NOTE:
    What controller are you trying to do this for?
    A40, A50, E46, E35A, E35B, E86A and E86B are ECMs that the software defaults to 3 byte addressing - is it one of those?
    On closer inspection, it appears that the E35A and E35B only support 3 byte addressing, the E86A and E86B appear to support 4 byte addressing.
    It was most likely a copy/paste error when setting up the E86A/B config files (based off of the E35 config files) that they got set to 3 byte addressing instead of 4.
    So if it is E86A/E86B that you are working on (I presume it is based on previous posts) then try the attached/updated *.pmm files - which allow for 4-byte addressing.
    E86_DMA_4_Byte_Addressing_Fix.zip
  5. #25
    I'm adding FlexFuel to my Sonic (Ross your write up from 2012 for your Cruze was very helpful!) and it appears I'm missing the FlexFuel Diagnostic enabler (B0186) in my OS (12655493). I believe this only enables/disables the FF sensor diagnostics to lookup the 2 DTCs related to the sensor, it'd be a nice-to-have if it's not much work.
  6. #26
    Apr 2008
    After this latest update it has left V7 & V8 completely unusable. Tried doing a complete uninstall and deleting all files and registry entries and reinstalling. Same issues V7 gets a Stream Write Error and V8 get 10 to 15 Access Violation Errors. Have to use task manager to force quit the program. Please help.
  7. #27
    Quote Originally Posted by nm2769 View Post
    At what stage do these errors occur? What steps do you perform after the software starts before the errors show up?
    Some detective work you can try:
    For V8, hold down the Ctrl key on the PC keyboard and double click the V8 Scan and Tune icon to start the software. That should create trace/log files in the \Documents\EFILive\V8\Trace folder. Look in those files (using Notepad) to see if you can see any reason for the errors.
    For V7: Change the properties of the desk top icon so that the "Target" field has a space, forward slash, lowercase L after it, like this:
    Then run the V7 software, that will create a log file in the folder: \Program Files (x86)\EFILive\V7.5 called StartupLog.txt.
    You will need to right click on the desktop icon and select "Run as Administrator" otherwise V7 won't have permission to create the log file in the "Program Files (x86)" folder.
    Again, check that log file for any clues as to why those errors occur.
  8. #28
    Apr 2008
    Paul, the errors occur at startup. Both V7 & V8 get the errors immediately after the program starts. V8 has what seems like an endless Access Errors at startup and I have to use task manger to force close it. V7 error pops up and when you click ok V7 closes on it own. I checked the trace/log files and I don't see anything that points to the issue. I broke out an older laptop that still has windows 8 on it and have been using it for now. I'm not sure if there are some issues with windows 10 or what that may be causing issues with EFILive. I'm going to reset the windows 10 laptop and see if that helps. I'm not sure what else to do.
    Nick
  9. #29
    Nick
    It just might be a driver issue since both V7 and V8 attempt to use the USB driver to detect any FlashScan/AutoCal devices on startup. You could try completely removing the drivers and re-installing them as per the first post in this thread.
    https://forum.efilive.com/showthread...al-USB-drivers
  10. #30
    Feb 2016
    Default Error Trying to update
    I'm getting an error when V8 tries to update. Haven't tried 7.5 yet. Screenshots attached. I tried it closing V8 before trying to update and with leaving V8 open.
Name:	V8 Update Error 1.JPG
ID:	22697   Click image for larger version.
Name:	V8 Update Error 2.JPG
  1. Current Public Release (May 2018)
    Last Post: July 5th, 2018, 11:36 AM
  2. Current Public Release (Oct 2017)
    Last Post: October 25th, 2017, 04:55 PM
  3. Known Issues With Current Public Release
    Last Post: March 22nd, 2017, 11:42 AM
  4. Known Issues With Current Public Release
    Last Post: February 17th, 2017, 07:06 AM
  5. Known Issues With Current Public Release
    Last Post: January 31st, 2017, 12:02 PM
