Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Current Public Release (Updated - Feb 2019)
    Default Current Public Release (Updated - Feb 2019)
    Release Notes:
    Version Numbers:
    After installing this release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.27 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.23 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.008 (Jul 4, 2018) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.139 (Nov 26, 2018) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Download here:
    Known Issues:
    Issue #1:
    Workaround:
    None.
    Issue #2:
    Workaround:
    Issue #3:
    When displaying logged data in the V8 Scan Tool on the [F3: Data] page, the PID values always display in their base/metric units - regardless of the user selected display units. The Minimum, Average, Maximum and Std Dev values correctly display in the user selected display units.
    Workaround:
    Ensure the user selected units are always the PID's default metric units.
    Will be fixed in the next update.
    Dec 2012
    Sweet! Thanks!!!
    Question,
    Trying to define a User Defined PID, When I hit "Generate" in the compiler, it gives me the error "Invalid DMA Address: 'D0001480'"
    Im assuming there are limitations on the addresses? Is there a way to get them raised as I know the address is valid and able to call it via other tools.
    Josh
    '04 GMC LLY
    Sweet! Thanks!!!
    Question,
    I'm pretty sure there is no numerical limit on the DMA address value (other than the 32 bit limit).
    That error occurs when there is a mismatch between the number of OS numbers listed in the "OS=" line v's the number of addresses listed in the <DMA_PID>= line.
    My bad, the DMA address is handled as a signed value. 0xD0001480 is negative when treated as a signed 32 bit value. That is triggering the "BAD Address" error.
    I'll look into a solution...
    Sweet! Thanks!!!
    Question,
    Updated version of EFILive_UserPID.exe that handles DMA addresses as unsigned 32 bit values. Available here: http://download.efilive.com/Software...ve_UserPID.rar
    Also, please see the comment in the LS1B.ini file in the "User Defined PIDs" folder. (Ignore the part about 24 bits, I have just increased it to 32 bits, unsigned)
    But be aware that for the named controllers the most significant byte is automatically ORed into the address by the EFILive software.
    Code:
    ; __________________________________________________________________________
    [Dma_Addr]
    ; The [Dma_Addr] section describes the memory addresses for each DMA PID
    ; for each supported operating system.
    ; DMA PID addresses are specified as hexadecimal WITHOUT any '$' or '0x' prefix.
    ; Any address defined as . means that the DMA PID is not defined/available for the corresponding operating system.
    ; These are just sample address values (not real address values) to show how the address values for each PID
    ; are placed in the same column as the OS for which they are intended.
    ; NOTE:
    ; Some controllers use 32 bits for DMA addresses, EFILive only allows 24 bit addresses to be specified in this file.
    ; EFILive automatically adds the most significant byte as follows:
    ;  - For E39, E39A, E78, E92, E98, E80, E81, E82, E84, T87, E83A and E83B EFILive ORs the DMA address provided with 0x40000000
    ;  - For E20 and E40 EFILive ORs the DMA address provided with 0xFF000000
    Dec 2012
    Awesome!
    Ill give it a shot!
    Josh
    '04 GMC LLY
    Dec 2012
    Everything compiled correctly. Gonna run out and test.
    Second Thing.
    Running on the new software and have a customer trying to flash an E86B. Its making it to around 55-60% full flash and we are getting an $0311 code bbx. Unfortunately they cant pass through.
    E86B_Failed_Flash311.zip
    Josh
    '04 GMC LLY
    Josh, is this the first time the customer has tried to flash that vehicle?
    The error indicates the ECM is not in the correct mode for programming, not sure why which is why I asked is this the first time for the vehicle or just since the update.
    Dec 2012
    This customer has been running tunes for about 2 years now with no issues. He requested the most updated tunes we had today, so he updated to this release, and that's when the issues started. The files we sent him today, nor any of his old files will Full Flash. He can cal flash any of the files with an 80% or so success ratio, but the truck is in a no start condition.
    Josh
    '04 GMC LLY
    Dec 2012
    Code:
    [Dma_Addr]
    ; NOTE:
    So made it a little further. The PIDS compile. When I try to validate them, it seems to be pulling the Speedo System Segment # as the OS #?
    Not trying to be a pain in the ass.... Just pushing extra buttons today i guess.
Name:	PID Detect.PNG
    Josh
    '04 GMC LLY
  1. Current Public Release (May 2018)
    Last Post: July 5th, 2018, 11:36 AM
  2. Current Public Release (Oct 2017)
    Last Post: October 25th, 2017, 04:55 PM
  3. Known Issues With Current Public Release
    Last Post: March 22nd, 2017, 11:42 AM
  4. Known Issues With Current Public Release
    Last Post: February 17th, 2017, 07:06 AM
  5. Known Issues With Current Public Release
    Last Post: January 31st, 2017, 12:02 PM
