Results 1 to 4 of 4
Thread: rev limit change - manual transmission
    Jan 2019
    Default rev limit change - manual transmission
    Newbie, but got her to run today with help from this forum.
    Thought this lesson learned was worth sharing :
    In addition to tweaking the pedal and torque curves to modestly increase torque, I raised the hard ( 4000 ) and soft rev limits ( 3800 ) , torque, pedal, and timing tables to support 3800 RPM. At first the ECM still limited me to 3200 RPM but bounced harder off the limit (hmm, seems the increased torque parameters were working) . Then I stumbled upon another setting. It is a setting that only shows up with V7.5 running, tune selected, and plugged into my truck, key in run position. It presents at the bottom of the "Internal Flash" list and is titled " Operation Monitor ". it's parameter ID is F8812 or {F8812} . I had to set it to disabled , save the tune, then reload with V8 to allow revs over 3200. It is now a dream to drive shifting gears at 3500 RPM and not yet on the rev limiter .
    2017 2500 CC 6-sp 4WD RIP: 98.5 F250 7.3 6-sp, 2006 Duramax 6-sp
    That F8812 parameter is used to control a complex algorithm in the background that monitors the RPM, Fuelling etc. It is sort of like a co-pilot to the main mapping just making sure the final fuelling, torque calculation don't end up at something way out of range. Rather than try to massage those numbers to suit changes tuners just wanted to be able to disable it. I have a feeling some of the factory calibrations may have had it turned off too.
    Nov 2010
    What ecm are you using?
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Jan 2019
    Quote Originally Posted by 2007 5.9 View Post
    what ecm are you using?
    2350b
  1. Rev limit question
    By paul@thrill-ride in forum Gen III V8 Specific
    Last Post: September 19th, 2013, 09:56 AM
  2. 6.2 Timing and Rev limit help?
    By TorqueMonster007 in forum Gen IV V8 Specific
    Last Post: August 5th, 2013, 07:39 AM
  3. Lb7 rev limit, and fueling help please
    By Jstewy21 in forum General (Diesel)
    Last Post: December 11th, 2012, 04:24 AM
  4. E67 Rev Limit???
    By Meister in forum E37, E38 & E67 PFI ECM's
    Last Post: October 15th, 2012, 05:31 AM
  5. Manual Trans Rev Limit E38, 2010 Camaro?
    Last Post: May 9th, 2012, 09:17 AM
