Thread: 2012 Duramax efi issues
    Jan 2019
    Default 2012 Duramax efi issues
    Hello folks
    I am knew here and am sure I can be pointed in the right direction. I recently purchased a 2012 duramax that has a delete and it recently quit. After a new cp4 and airdog lift pump and filter housing I am still experiencing some issues. It starts and runs fine than i shut it off and starts and dies. After flashing to program1 on provided efi card I get
    Do you know who tuned it? It sounds like a company has provided those tunes to the previous owner therefore it is best to try to make contact with them about it as EFILive would have no idea what modifications they have made to the tuning.
    Jan 2019
    I may be able to find out.. what do I ask them for .. program or software number...
    No I meant find out the tuners name that supplied the tunes and then contact them directly about the running issues.
    EFILive does not provide tunes, they build the hardware and software for tuners to build tunes with. So you need to know what tuner built the tune(s) for your truck so they can help, otherwise you'll need to find a tuning shop and buy a tune from them.
    Try the return line regulator for the injectors, it’s the round black thing by the thermostat that has the small injector return lines going to it.
    04 LB7
    2010 LMM
    2015 LML
  1. 2012 Chevy Duramax
    By John301 in forum General (Diesel)
    Last Post: July 10th, 2019, 02:40 PM
  2. Replies: 0
    Last Post: September 23rd, 2016, 06:55 AM
  3. 2012 Duramax Deleted, Now Exhaust Hiss
    By LukeBright in forum Diesel
    Last Post: January 14th, 2016, 05:02 AM
  4. EFILive Class in Kinder LA March 3-4th 2012, Duramax and Cummins
    By dansdieselp in forum General (Diesel)
    Last Post: January 8th, 2012, 01:38 PM
  5. Replies: 0
    Last Post: January 7th, 2012, 04:01 PM
