Results 1 to 2 of 2
Thread: Advice on tune
    Aug 2007
    Default Advice on tune
    Hi Guys
    I've been slowly chipping away at my tune.... It's not my daily so i might only get it out once every month or 2.
    Today I drove my car to work and wanted to work on the bucking I'm getting on light throttle while going up the freeway.
    I have attached my 3 logs from today and my so far 2 changes of tune.
    Can I ask If i seem to be doing the right thing by modifying the throttle follower, it seems to be removing the light on throttle bucking.
    I also think I have missed a setting with turning on my o2 sensors with a closed loop mafless os, could anybody advise on this.
    Another thing I noticed today was it seems that my v2 is showing the afr at 13.7:1 but lamba on my logs is showing 1.0, have I set my commanded afr incorrectly or is my map setup incorrectly.
    Thanks for any advice
    Cheers Wade
    Hi Wade,
    I was out of town (again) so I could not look at your files.
    I'm back now (catching up), so I'll take a look after work.
    Sometimes whhen I see that, I start again with a stock file and add only the necessary changes (VE, MAF, injectors), nothing else.
  1. learning to tune. any advice?
    By tunerintrainning in forum Duramax LLY
    Last Post: July 4th, 2015, 09:36 AM
  2. First 6.7 Tune, looking for advice.
    By bill1977 in forum Cummins 6.7L
    Last Post: June 26th, 2014, 01:44 PM
  3. Advice needed, please take a look to my tune
    By DocZ28 in forum Gen III V8 Specific
    Last Post: October 17th, 2012, 01:12 PM
  4. Good N/A Tune but...Going Supercharged I could use advice on a base tune
    By tatasta in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 6th, 2011, 09:16 PM
  5. Advice on my transmission tune.
    By ippielb in forum Gen III V8 Specific
    Last Post: October 20th, 2010, 10:53 AM
