Thread: Data Display in V8
    Feb 2016
    Default Data Display in V8
    Searched but did not find anything. When I load a scan file in V8 and view the data there are a number of PIDS that display incorrectly. Some the precision is off CADWP, FRP_C, some like boost, map seem to display KPA regardless of choice ie PSI, MPA etc.. The Baro reads 97 and never changes regardless of choice when viewing. Works fine in 7.5 scan tool.
Name:	V8 Baro Pid.JPG
ID:	22643   Click image for larger version.
Name:	V8 Scan Pids.JPG
ID:	22644   Click image for larger version.
Name:	V8 Scan Data.JPG
    Can you post your log file, and the V8 dash files.
    Feb 2016
    Here is a log file. Do you want the .dsh file or the pid txt file that was created with the pids I use?
    Feb 2016
    Anything on this?
    I'm able to reproduce this, I notified Paul.
    Quote Originally Posted by Bdirtymax View Post
    Working on a fix for these issues in the next update.
  1. Replies: 4
    Last Post: April 5th, 2017, 05:54 AM
  2. Calc pid to display previous frame value (delay data)
    Last Post: February 13th, 2017, 03:25 AM
  3. Converting Ford style injector data to data useful to EFI Live.
    By JOHNBOY in forum General (Petrol, Gas, Ethanol)
    Last Post: May 11th, 2012, 06:19 AM
  4. BBL data display/record decimal places
    By Kevin Doe in forum FlashScan V2 BB Logging
    Last Post: March 27th, 2008, 03:46 PM
  5. scantool display to use as dash display?
    By ace68 in forum Lounge
    Last Post: March 3rd, 2006, 06:50 AM
