Results 1 to 5 of 5
Thread: GM.GearCom PID causing error report
    Aug 2012
    Default GM.GearCom PID causing error report
    Trying to diagnose a 4l80e not upshifting. I am trying to log gm.gearcom (commanded gear) but whenever I select that PID (had to validate to make it active) and then try to connect I get a 'generating error' report ($31 I believe). I tried to connect multiple times after restarting, new cable, etc... finally connects ONLY when I disable that PID.
    Desperately need this PID to figure out why I'm not shifting out of first ( I can command gear changes through DVT. VSS is dead on, TPS reads correct, shift table is normal, MAP reads normal)
    Aug 2012
    Since I tried doing this I have updated the V2 firmware. I have yet to try logging again since the truck is an hour away. I just want to come prepared when I make the drive.
    The pid is GM.GEAR
    post your V2 config file.
    Aug 2012
    Now is gm.gear the commanded gear OR the current gear? I believe I had the current gear PID working fine. I wanted to see if the PCM was saying ‘shift’ or not.
    GM.GEAR is the commanded gear.
    The pids GM.GEARCOM and GM.GEARCURR are for Allison and not for 4L60E/4L80E.
  1. ls1a error report maf HZ
    By Tool Guy in forum Gen III V8 Specific
    Last Post: July 21st, 2018, 03:58 AM
  2. Ls1 Logging error report
    By Tre-Cool in forum Gen III V8 Specific
    Last Post: December 7th, 2012, 04:49 PM
  3. error updating pid in bbl
    By nathans1987 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 1st, 2010, 07:47 AM
  4. Error Report.
    By horsehaulin in forum FlashScan V1
    Last Post: June 5th, 2008, 09:59 PM
