Results 1 to 5 of 5
Thread: LBZ GPCM change
    Mar 2018
    Default LBZ GPCM change
    Hi I need to change out my Glow controller on my LBZ but not sure on how to re-link the new GPCM to the ECM, please keep any advice "simple" still new at this game and using a V2 with laptop
    Regards Bruce
    Regards Bruce
    Nissan GU Patrol
    06 LBZ Duramax, Allison trans
    Transco JR kit and pump pressure upgrade
    EGR removed, custom made inter-cooler pipework, DP5 switch
    I think you might need it programmed via GM TIS first (assuming it's new).
    Need official EFILive help, please go here.
    For tuning support please post your questions on this forum (or other auto forums).
    Sorry if I don't respond to your PM, don't take it personal.
    Mar 2018
    I should of mentioned that it was a second hand GPCM and I am running a set of non stock tunes (DP5)
    Regards Bruce
    Nissan GU Patrol
    If the GPCM is used then I think the V2 can do what you need, plug it in to the OBD-II port.
    Press F2 - Tune Tool
    Press F2 - Injectors
    Press F3 - Read ECM Inject
    Press F2 - Program GPM Inject
    That should read the stored values in the ECM and program them in to your new (used) GPCM.
    Mar 2018
    Regards Bruce
    Nissan GU Patrol
  1. What to change and how to change
    By gigabrock in forum Duramax LB7
    Last Post: July 20th, 2012, 04:52 AM
  2. change os or not and how to do it?
    By rennat_2006 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 9th, 2011, 07:36 PM
  3. LBZ gear change
    By IdahoRob in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 28th, 2008, 02:25 PM
  4. Change to Manual Trans with LBZ
    By thetallengineer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 23rd, 2007, 04:42 PM
  5. LBZ tire size change
    By BigTex in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 12th, 2007, 03:14 AM
