Results 1 to 7 of 7
Thread: e78 VATS
    Feb 2019
    Default e78 VATS
    hello to everyone,
    I purchased this EFIlive flashscan v2 some time ago. I didn't need it but had a great deal and I knew i'll need it some day.
    Some time ago, I built a 1.4t bench engine coming from a 2013 Chevy trax for a school project that is equipped with a E78 ECM.
    It ran great for a few months but kids being kids and learning the basic of mechanic, they somehow made an electrical short in the BCM and now the engine is immobilized by the VATS system
    ECM challenge from the BCM always fails. I tried reprogramming it with online SPS but nothing works.
    Instead of replacing the BCM, I thought about removing the VATS system from the ECM.. or patching it
    Is this even possible to turn off the VATS into those E78 using my flashscan V2 ?? or using any other method ? I also have a KESS master programmer if that's any help.
    Thanks for your help
    Yes EFILive can disable the VATS on the E78, it needs to be done as an ECM OS patch on them (there is no VATS disable in the calibrations) but it can be done. Worst case it'll cost you a VIN license to hopefully discover that is all that was wrong.
    Need official EFILive help, please go here.
    For tuning support please post your questions on this forum (or other auto forums).
    Sorry if I don't respond to your PM, don't take it personal.
    Feb 2019
    Thanks. I don't really understand what ECM os patch means since I just installed the software for the 1st time and haven't played with it ...
    But I guess I'll find out after playing around with it.
    Thanks for the info. Can't wait to play with my new toy. I've heard good things about it.
    Well, to make life easier, read the ECM out (you have to use EFILive V8 to read an E78) and post your .ctz file up here, we can assist from that point on.
    Feb 2019
    here it is.
    I played a bit with the software... I saw plenty of stuff but no switch for VATS
    thanks
    If you start the V7 software with your V2 plugged in to the USB port you will see the VATS patch option (I just checked, it is there for this E78).
    As the description says "After applying this patch you must perform a 'Full Flash' of the ECM."
    Also I think on these ECM's they want a load on the starter enable relay, just a relay or resistive load works as though it was the starter relay.
    Good luck.
    Feb 2019
    Thanks, I was looking on demo mode. That switch wasn't there... Good to know
    Learning my way.
    Have a good day
  1. E78 VATS Relearn
    By SkyMadness in forum E78, E83, E84 PFI ECM's
    Last Post: January 13th, 2014, 09:55 PM
  2. E78 VATS Relearn
    By SkyMadness in forum E39, E80, E82 & E92 SIDI ECM's
  3. E78 Vats Relearn
    By SkyMadness in forum General
    Last Post: January 13th, 2014, 01:59 PM
  4. E78 1.4 cruse vats patch?
    By MattS in forum E78, E83, E84 PFI ECM's
    Last Post: May 9th, 2012, 02:01 PM
  5. E78 1.4 cruse vats patch?
    By MattS in forum E39, E80, E82 & E92 SIDI ECM's
