Results 1 to 4 of 4
Thread: Checksum Errors LBZ
    Mar 2015
    Default Checksum Errors LBZ
    Hey Guys.
    Sorry if this is a dumb question, but EFILive is a whole new learning curve for me (coming from HPTuners), and I've never ran into this issue with my truck when tuning with HPT. So when I did an initial read on the truck I keep getting these 2 checksum errors (see attached pic). Is this something I should be concerned with and is it safe to "Force All Segments' Checksum To Be Correct".? If this need to be addressed, what is the best way to remedy the issue?
    Thanks in advance guys,
    John
Name:	07 LBZ Invalid Checksums.jpg
    09 Cobalt SS (LNF) - EFR6758, bunch of goodies, 470whp/409wtrq via "the other guys" software.
    07 Silverado 2500HD (LBZ) - officially turned to the dark side.
    Hi John,
    I can only assume that you have modified calibrations in those two segments with HPT but it looks like they do not correct all the checksums those Bosch ECM's have (and there is plenty). Some aren't actually checked by the ECM but we calculate them all just incase.
    Normally "Force All Segments' Checksum To Be Correct" isn't something we'd recommend but in this case I would say you should be fine.
    Mar 2015
    Thanks GMPX! I'm happy to report I successfully attempted the "Force All Segments' Checksum To Be Correct" without any issues. I was legit worried I'd end up with a freshly bricked ecm on my hands, but all went well. Thanks again!
    Well that can certainly happen, good to hear it worked out.
  1. errors on my v2
    By DHarrienger in forum FlashScan V2
    Last Post: February 28th, 2016, 11:43 AM
  2. Holden / Pontiac TCM Checksum errors
    By bK in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 21st, 2008, 03:02 PM
  3. Holden / Pontiac TCM Checksum errors
    By GMPX in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: April 21st, 2008, 02:59 PM
  4. Table errors
    By Biodiesel66 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 26th, 2006, 07:32 AM
