Results 1 to 2 of 2
Thread: help with idle timing in park b0950
    Feb 2019
    Default help with idle timing in park b0950
    im fairly new to duramax tuning but understand the basics. i have been having a problem with a rolling/unstable idle only when warm and in park or neutral. foot on brake or A/C on makes no difference, frp stable and matched desired. injectors and fpr are new bosch units. im seeing in b0950 it calls for -5 degrees of timing when when above conditions are met. i think this might have somthing to do with the idle problem. i plan on advancing it a little (in b0950) but have some questions. other than noise, why would GM want the timing that retarded under these conditions? also what would be a good starting point for agjustment? 04.5 lly auto with 200k miles. thanks, i appreciate any help/thoughts.
    Feb 2019
    so I guess the lly section is kinda dead nowdays..LOL. I went ahead and changed timing from -5 to +2 degrees in b0950, at operating temp 6-800 rpm. it make the idle quality much better with hardly any increase in noise. I will continue to monitor. Hope this helps somebody someday.
  1. Timing Showing 0 during Idle
    By JordanSBC427 in forum Gen III V8 Specific
    Last Post: June 13th, 2014, 09:30 AM
  2. e38 6.2L conversion from 5.3L timing bounce in park only not drive XXX
    By huttner1 in forum E37, E38 & E67 PFI ECM's
    Last Post: June 13th, 2013, 09:31 AM
  3. Car is too rich at idle in park / perfect in gear
    By exploder in forum Gen III V8 Specific
    Last Post: December 3rd, 2008, 12:59 AM
  4. Can't get my truck to use the idle park/neutral tables
    By Highlander in forum General (Petrol, Gas, Ethanol)
    Last Post: October 17th, 2005, 03:05 PM
  5. Idle Timing?
    By trudynosports in forum General (Petrol, Gas, Ethanol)
    Last Post: June 20th, 2005, 01:29 AM
