Results 1 to 2 of 2
Thread: 4l60 to 6l90 trans swap in 08 sierra, where to start?
    May 2011
    Default 4l60 to 6l90 trans swap in 08 sierra, where to start?
    I am looking to get started on this trans swap for my 08 sierra 1500. the parts side im not worried about its the computer side. is the trucks computer able to be flashed for a base 6l90 tune and i would be left with harness work to go from the computer to the 6l90 or is this just a no go all around?
    (edit- i know the engines computer doesnt control the 6l90, the 6l90 has its own internal computer. more less can the trucks ecm be flashed to communicate with the 6l90 tcm?
    Sep 2007
    http://www.ls1truck.com/forums/power...0-a-print.html
    This guy did it, might see what's needed. I glanced through, according to the thread you have to buy a new ECM because you'll brick yours if you try to flash in the 6 speed.
  1. engine wont start on 4l80 tune, runs on 4l60
    By BagD72Chevy in forum Gen III V8 Specific
    Last Post: June 2nd, 2016, 09:49 AM
  2. Trans Segment Swap?
    By LS-SWAPPER in forum General (Petrol, Gas, Ethanol)
    Last Post: September 17th, 2012, 07:39 AM
  3. Scaling Sanity Check and 4L60 Trans Cal
    By TurboCamaro in forum Gen III V8 Specific
    Last Post: May 13th, 2012, 04:22 PM
  4. 2009 Silverado 4.3l/4l60 to a 6.2/4l80 engine/trans swap = ABS lite
    By mowton in forum Conversions / Aftermarket Parts
    Last Post: May 13th, 2012, 03:38 AM
  5. 2008 GMC Sierra trans question
    By Spindoctor in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: April 5th, 2009, 06:26 AM
