Results 1 to 3 of 3
Thread: Having trouble after firmware udate
    Lifetime Member HellKnightHicks's Avatar
    Mar 2011
    Default Having trouble after firmware udate
    Updated boot block.
    Got an odd error message.
    Had to close the update tool.
    Re open update tool.
    The flashed the firmware.
    The flash and scan comes on and boots up.
    I get the toast message for the tool bar Icon
    Windows 10
    Click that icon.
    Get Error: $0024: EFILive_Hapi is not running
    I looked into this thread and it doesnt seem to pertain to my issue. Hapi is starting and is runnin but nothing can use it.
    https://forum.efilive.com/showthread...pi-won-t-start
    I tried starting the service myself. no luck
    Tried running Hapi with admin rights as well. no luck
    Removed SD Card from flash and scan. Lo luck
    Is it possibly something wrong with the flash to my V2 Box?
    The flash and scan 2 is now comming up blank from time to time.
    I did not disconnect the device at any point when following the instructions for flashing that were on screen..... Im beginning to feel like its my actual flash and scan Box
    If any apps are open they the flash and scan stays blank. If i close all EFILive apps then the flash and scan boots up.....
    Hope somebody can help.
    Mar 2011
    Contacted So Cal Diesel in CA and they helped me out quite a bit. Learned a few things.
    I continued testing the unit and figured out that it ended up being my USB cable. I changed that and everything seems to be working properly now.
    Good to hear.
  1. Having a little trouble with my first 6.7
    By shakinlm7 in forum Cummins 6.7L
    Last Post: October 5th, 2015, 12:08 PM
  2. Firmware 2.06.10?
    By samh_08 in forum FlashScan V2
    Last Post: May 27th, 2009, 12:02 PM
  3. Firmware For V1?
    By JET LEE in forum FlashScan V1
    Last Post: March 3rd, 2007, 04:56 PM
  4. new firmware help-please!!
    By dynarex in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 14th, 2007, 11:22 AM
