Results 1 to 4 of 4
Thread: DSP2 enable
    EFILive Reseller
    Nov 2005
    Default DSP2 enable
    OS # 02600601
    In the DSP2 enable I have a numerical value option only. Default value is 0.0. Do I set this to 1 using programmer logic, or is my version of this OS hosed?
    www.kennedydiesel.com
    Specializing in Duramax Performance
    More than just a salesman-I use and test the products that I sell on a daily basis.
    Superflow Lie Detector in house
    Oct 2004
    Download the latest release if you haven't already. There was an error in the calibrations a while back where custom OS options with button choices showed as regular number fields (like you are seeing). I had the same issue with LS1 OS.
    Andrew
    EFILive Crew
    I've sent you an Email John.
    EFILive Reseller
    Nov 2005
    Thanks Ross! Too many machines to keep up with, it looks like my dyno PC was a bit outdated. All is well, and setting to 1 did get it enabled.
  1. HOW TO....enable GM.ENGOILP
    Last Post: December 15th, 2009, 02:47 PM
  2. egr enable
    By kostelacd69 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 6th, 2009, 07:01 PM
  3. HELP!!! AFM won't enable....
    By GAMEOVER in forum Gen IV V8 Specific
    Last Post: January 18th, 2009, 10:50 AM
  4. How Do I Enable IAT with MAF Disabled?
    Last Post: May 14th, 2006, 07:34 AM
  5. What rpm to enable LTFT?
    By Rich in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2005, 06:56 PM
