OS # 02600601
In the DSP2 enable I have a numerical value option only. Default value is 0.0. Do I set this to 1 using programmer logic, or is my version of this OS hosed?
OS # 02600601
www.kennedydiesel.com
Specializing in Duramax Performance
More than just a salesman-I use and test the products that I sell on a daily basis.
Superflow Lie Detector in house
Download the latest release if you haven't already. There was an error in the calibrations a while back where custom OS options with button choices showed as regular number fields (like you are seeing). I had the same issue with LS1 OS.
Andrew
EFILive Crew
I've sent you an Email John.
Thanks Ross! Too many machines to keep up with, it looks like my dyno PC was a bit outdated. All is well, and setting to 1 did get it enabled.
