Results 1 to 9 of 9
Thread: Torque Response Tuning
    Lifetime Member HellKnightHicks's Avatar
    Mar 2011
    Default Torque Response Tuning
    So now that modern ECM's don't directly correlate TB blade position with pedal to Increase Throttle Response we have to adjust the commanded power.
    Example Chevy 2015 Z71 E92 ECM
    Table Commanded Power Mode A B8802
    I notices there's a large dip in the middle of the curve. I have reduced that dip increasing areas of the table by 5% at a time. Then Smoothing.
    I left the 0 TPS stock as I'm sure its a bad idea to mess with anything at 0% TPS
    In order to get more power if I understand this correctly I have elevated the final Column from 320kw to 400kw. I know this is done based on https://forum.efilive.com/showthread...ighlight=B8802
    However thats a boosted application. My reasoning/guess is that the ECU is never attempting to produce the full potential of the engine.
Name:	B8802 Before and After.png
    Straighten me out here if I'm wrong.
    I can edit this and we can make this a basic tutorial as my understanding solidify's.
    Aug 2018
    Quote Originally Posted by HellKnightHicks View Post
    What I have noticed is that when I DON'T turn this table up. the throttle blade closes to maintain the factory TQ rating.
    So I always tune this to go up above what the power of the car is making.
    I also have copied over a Corvette base throttle settings to a truck. It really helps with throttle response.
    Mar 2011
    Quote Originally Posted by SOMFormula View Post
    What Corvette did you take it from... So that I may search for that base tune.
    Aug 2018
    2014 Stingray A6
    It has the same engine.
    I was tuning a Whipple Silverado. So I started with some car settings to see if I could liven it up a bit. Then I modified it further from there.
    The trucks seem real lazy from the factory.
    Mar 2011
    Yea thats what I noticed. After re-mapping that table in a truck I was tuning it came alive. It was nutz. I was doing a drive and tune with him and he hammered it and the thing $hit got it. Didnt expect it to have that kind of get up from a stock truck. I dont know why the hold them back so much like that.
    Any places i can find a stock file for that setup?
    Aug 2018
    E92 - 2014 CHEV CORVETTE Z51 A6 (12660065) - STOCK FILE.ctz
    Mar 2011
    Thanks my dude.
    I dont know why the hold them back so much like that...
    Probably to set pricing model Corvette>Cadillac>Trucks
    Mar 2011
    Just picked up a 2017 denali. Its got the 6.2L v8. Quite lethargic at lower throttle. Applying same principal. Shame we cant tune the trannys.
    I specifically picked this truck because we can still tune them. Im not a fan of AFM/DOD Probably cam it later.
  1. Torque response and Tq Control Tables
    By Rhino79 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 13th, 2013, 01:04 AM
  2. No response from vehicle
    By MattysTA in forum Gen III V8 Specific
    Last Post: June 26th, 2008, 10:39 AM
  3. Tuning out dips in torque (with a big cam)
    Last Post: May 6th, 2008, 02:19 PM
  4. Tuning for a 3000 stall torque converter
    By dirt_track_racer_81 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 5th, 2006, 03:03 PM
  5. Crisper throttle response with tuning possible?
    By 2000ssnb in forum General (Petrol, Gas, Ethanol)
    Last Post: March 6th, 2005, 06:03 AM
