Thread: E38 a/c disable/enable rpm
    Feb 2019
    Default E38 a/c disable/enable rpm
    I have a 2010 camaro ss E38 ecm.
    Whats your take on disabling the compressor at higher engine RPM's?
    Does the tables in Systems/AC params G0103/G0104 work?
    If so, which pin on J1/J2 would connect to the compressor thru a relay?
    I am using a VA a/c system with a trinary switch to control the fans and would add another to control the compressor rpm on/off?
    If that works!
    Thanks, Chuck
    May 2012
    is this on a custom swap?
    Feb 2019
    Yes...It's in a 55 Chevy
    May 2012
    Quote Originally Posted by 5557nut View Post
    E38 will not be able to control AC compressor by itself, it needs can data message to activate it, you need BCM and AC controls, there is a company that sells a module to produce this signal.
    If you wire the AC pressure sensor, it may activate FANS when needed.
    why not use ECM to control Fans?
    Feb 2019
    Yes I am using the ecm for fans. I miss-spoke. I meant using to trinary to control compressor.
    It appears the settings in the ecm for ac rpm is non-functional.
    I guess I'll have to remember to turn off the ac if I do burnouts.
    It may not be critical to be concerned about compressor rpm since my Sanden SD7B10 is 6500 constant and 9300 downshift.
    I guess GM quit using that control like the LS1 when they started using control modules to consolidate wiring.
    Thanks for helping out.
    2010 Camaro SS LS3 in a 55 Chevy
    Manual 6 spd
    Texas Speed 2" headers w/3" exhaust
    Texas Speed cam 229/236 .629/.615 112 LSA
    Hi-Ram intake stock injectors
    Nov 2014
    not sure i understand. will a/c control (g0101-6) work on a 07 ls7 c6z06 or not?
  1. missing dtc enable/disable
    By mrrattle in forum Cummins 6.7L
    Last Post: February 5th, 2019, 08:41 AM
  2. Idle spark enable/disable by VSS?
    By DrX in forum Gen III V8 Specific
    Last Post: July 25th, 2011, 02:19 PM
  3. Tweaking the 2010 camaro air conditioning enable/disable Parameters ?
    By 2010 Bumblebee in forum E37, E38 & E67 PFI ECM's
    Last Post: May 5th, 2010, 05:39 AM
  4. B4206 disable or enable during AutoVE tunning?
    Last Post: October 10th, 2007, 10:40 AM
  5. What rpm to enable LTFT?
    By Rich in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2005, 05:56 PM
Tags for this Thread
