Results 1 to 4 of 4
Thread: Swapping LQ4 into 98 K1500 with stock 4L60, tables missing?
    Feb 2007
    Default Swapping LQ4 into 98 K1500 with stock 4L60, tables missing?
    I'm working on swapping a LQ4 into my 98 silverado. Today I powered up the ECM to get the program off of it. Of course it was a 4L80 truck so did the segment swap for the transmission and now that looks good. I'm curious though if i'm missing something as there is nothing about 4X4 other than a couple of WOT shift mode tables.
    My previous use of EFI live was for diesel tuning so not used to the gas thing but this engine is stock so just looking to make it all work for now.
    OS is 09381344 so engine is a drive by cable setup.
    Thanks for any input and help!
    Attaching the current tune file incase someone wanted to check to let me know.
    Feb 2007
    Picture of the project. Was down to just a frame at one point. Slowly getting things back together
    Which tune file did you get the 4L80E segment (and trans diag segment) from...?
    Feb 2007
    I swapped in 4L60E segment and trans diag. I found it on
    https://www.dropbox.com/sh/4ydh5wltk...nav_tracking=1
    Now that you ask makes sense that was likely from a 2wd truck? I wasnt thinking that far ahead i bet. I matched up the program number and figured perfect.
    Im just on my phone but it ended with a 44. I guess i need to locate a truck with same code and 4x4? Any ideas where to look by chance?
  1. E78 Missing Tables
    By a78turbo in forum E78, E83, E84 PFI ECM's
    Last Post: August 23rd, 2018, 02:33 AM
  2. Too many tables are missing in E78
    By wesam in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: April 20th, 2015, 04:40 PM
  3. harness and pcm question, swapping in an lq4 in place of my ls1
    By ryans1000 in forum Gen III V8 Specific
    Last Post: June 29th, 2013, 04:32 PM
  4. Misfire tables missing
    By 69camaro5speed in forum E37, E38 & E67 PFI ECM's
    Last Post: April 27th, 2010, 02:03 PM
  5. E38 Missing tables? Or I'm missing something?
    By gmtech16450yz in forum E37, E38 & E67 PFI ECM's
    Last Post: January 7th, 2009, 03:28 PM
