Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Car Running lean during idle and cruise under 2k
    Feb 2006
    Default Car Running lean during idle and cruise under 2k
    My car seems to be running very lean at idle and cruising while under 2k rpms. What paramaeters would I modify to increse the fuel under those conditions?
    EFILive newbie
    1999 Camaro SS A4 | LME Forged 347 | Yank SS4000 Stall | 226/234 Cam | Patriot LS6 Style heads 2.055 / 1.57 57cc 11.3 SCR | FLP Long tube headers
    We need a bit more info on the engine combo, what Operating System (GM or Custom EFILive), MAF or Speed Density?
    Feb 2006
    Quote Originally Posted by GMPX
    347 LS1 226/234 112 cam. And I am running an 2002 GM OS with the MAF.
    EFILive newbie
    Oct 2005
    Are you running stock exhaust?
    You might have an exhaust leak. Have you done any tuning or just logging so far?
    2014 VF SV LS3 Maloo.
    Jan 2005
    any chance you are running a FAST intake manifold?
    Oct 2005
    TAQuickness likes FAST intakes
    Quote Originally Posted by ringram
    Ringram--> <--TAQuickness
    FAST--> <--TAQuickness
    TAQuickness--> <--FAST
    Edit: I'm only allowed 4 emotiglyphs, I can't say more...
    Lifetime Member jfpilla's Avatar
    What is the AFR that you consider lean?
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Feb 2006
    No FAST intake. I thought I had an intake leak and replaced the intake and all seals.. I do not have a WB 02 but my ltft are +15 +20 during those ranges. The seem to be fine at the higher RPM though.. I can provide some logs if anyone is intrested.
    EFILive newbie
    Jan 2005
    have you tried spraying starter or carb cleaning fluid around the intake? What you are describing sounds very similar to the leaky manifold problems I am having. I to have replaced every gasket several times and cannot seem to get it to seal up. Just a thought.
  1. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 01:44 PM
  2. Replies: 3
    Last Post: August 9th, 2009, 10:50 PM
  3. Running Lean at Idle
    By mikeyayell in forum Gen III V8 Specific
    Last Post: December 28th, 2007, 07:55 AM
  4. Lean Cruise and Cruise Control
    By neil in forum Tuning For Economy
    Last Post: July 9th, 2007, 09:42 PM
  5. Lean cruise running rich
    By limited cv8r in forum General (Petrol, Gas, Ethanol)
    Last Post: May 12th, 2006, 01:12 PM
