Results 1 to 7 of 7
Thread: Emissions deletes Cummins HD
    Jan 2011
    Default Emissions deletes Cummins HD
    Hello,
    Assuming Efilive won't allow to do any deletes with the HD version? I am in Canada and Emissions are not required here.
    It would not be hard to make the ability to delete emissions location based.
    The parameters are not even in the software, I wouldn't know where to start if we wanted to do it. I understand what you are saying about location based but it's just easier to play by the rules when your #1 market is the USA.
    Jan 2011
    Fair enough
    Nov 2019
    Does the support extend to the CM2150D models?
    Yes the CM2150 is supported (D & E versions), but same as the original post there is no emission removal parameters for those ECM's either.
    Sep 2015
    Is there a way to read the file out with EFI live then open up in Calterm then flash back with efilive?
    No there isn't sorry, file formats between both tools are not compatible.
    However EFILive can convert Calterm Xcal files to use in EFILive, there is a program we include with the software to do this.
  1. 2012 cummins emissions removal with efi
    By Cwalt50 in forum Cummins 6.7L
    Last Post: December 9th, 2015, 07:53 PM
  2. Deletes
    By rage_blue in forum Cummins 6.7L
    Last Post: July 27th, 2015, 11:03 AM
  3. EFI and Deletes
    By ckrumholt in forum Cummins 6.7L
    Last Post: March 11th, 2014, 05:00 PM
  4. OS change deletes tach and speedo????
    By critter in forum Gen III V8 Specific
    Last Post: April 22nd, 2008, 12:05 PM
