Results 1 to 10 of 17
Thread: lm7 to lq9
    Mar 2019
    Default lm7 to lq9
    new to tuning so bear with me please 01 chevy 1500 with the lm7 went to upgrade cam found bad bearings and was in the middle of rebuilding a lq9 and decided once the lq9 is done im just going to use it instead now Im trying to stay with the ls1b if possible. what im asking is what would be the best way about going about swapping over to the bigger displacement can I transfer over the main ve for the displacement and other data to get it set up for a base tune I did do a cam and long tubes I lnow I will have to adjust idle and such but I was curious if I used most data from a lq9 stock tune would that get me close thank you for your time
    There are plenty of LQ9 tunes... try one of those closest to your year model, use it as your starting point.
    Mar 2019
    Oh ok I was in aware that that could be done so just swap the vin over on the tune and I dont have to change the os or anything
    Jan 2010
    The LQ9 didn't come out until 2003 1MB PCM.
    He has a 2001 512KB PCM
    You can use whatever tables are available in the 2003 LQ9 and copy them over to your 2001 LM7 file. I built one in the past but I would have to dig it up. We swaped a 2005 LQ9 into a 99 and used a 2002 Base file to get the E-fans functioning properly.
    Mar 2019
    That is what I was going to try to do cause of the electric throttle body in the lq9 tune just use what I need for the most part cause I also did a cam and intake so I know it will be a bit of work then dyno tunes after so thank you that's what I was curious about
    Jan 2010
    Here is the base file I made after a few minor adjustments to get the Efans working properly and a few adjustments for shift points.
    This is in no way a final tune. This was just to get it up and running. It was a Bone Stock LQ9.
    Jason 02Segment Swap LQ9_0003.ctz
    Mar 2019
    Thank you I will see how it goes
    Mar 2009
    Quote Originally Posted by 1FastBrick View Post
    Pretty sure the LQ9 came out in 02 with the 0411 red/blue pcm. Heres a copy of an 02 LQ9 file on dropbox. It is a DBW tune, so I wouldn't segment swap, just compare and swap.
    https://www.dropbox.com/sh/4ydh5wltk...nav_tracking=1
    Mar 2019
    here is a lq9 data for a ls1b 5.3 ecm if any one would go over it but this is what I came up with and the trans info needs more work but lines pressure have been adjusted and shift time have also been adjusted other than that stock tune
    Engine:
    - B3601 is set close to the stoich AFR for E85, is this the fuel you're running...?
    - B3606-7: possibly dangerous if those conditions arise.
    - B3608-9: set to 0.05 s.
    - B3616: set same as F-car (65% below 3200 rpm, 35% above 3200 rpm).
    - B2618: set to EQR 1.185.
    - B5913-14: set these same as F-car (and run 92+ octane, which you should be with any compression ratio above 9.5).
    Trans:
    - the WOT mph upshifts/downshifts are upside down (the downshift mph must be less than the upshift mph).
    - set throttle kickdown tables to 100% (to allow MPH shift tables to control shifting).
    - set desired shift times to 0.3 s.
  1. lm7 speed density tuning
    By 2003gmc1500 in forum Gen III V8 Specific
    Last Post: February 7th, 2017, 03:27 PM
  2. Replies: 45
    Last Post: August 19th, 2015, 01:06 PM
  3. Startup issues on 03 LM7 with a small cam?
    By LS1FREEK in forum Gen III V8 Specific
    Last Post: June 3rd, 2013, 12:08 AM
  4. 5.3 LM7 low idle
    By hoff2483 in forum Gen III V8 Specific
    Last Post: March 3rd, 2009, 12:13 PM
  5. 01 5.3 lm7
    By Big D in forum Gen III V8 Specific
    Last Post: February 24th, 2009, 06:21 PM
