Results 1 to 8 of 8
Thread: Turbo Swap
    May 2016
    Default Turbo Swap
    Are there any tables that affect input of the vgt? Our actuator is a 12vdc motor with 3 wire analog feedback and I need access to the feedback signal. We are swapping a gtb2260vk into it in favor of the gtb1652vkl.... Any insight is always appreciated!
    Sent from my LG-H932 using Tapatalk
    May 2016
    Bump
    May 2016
    bumping 44 views
    As in the position rescaling?
    May 2016
    Yes sir that be it! Looking for either analog voltage or hz, not sure... Drawing shows 3 wire analog pot for the actuator position sensor but I have a feeling based on inspection in the actuator that is not the case
    May 2016
    any steam? I wanted to ask you another side question... I would like to chip in, i would like to see what it is that you guys see. I dont know where to start? I have a stock file i read out with alien KESSv2 and am able to see the hex. Where do i begin the process?
    May 2016
    Found the signal being sent from the VGT to be in SENT protocol and I'm not able to alter that signal. Anything that we are able to do to change the type of input? Any way you could point me in the way of looking on my own?
    Sent from my LM-V405 using Tapatalk
    May 2016
    Bump
  1. 04 5.3 turbo 400 swap
    By 6.0vortecchevy in forum Petrol / Gas
    Last Post: May 26th, 2015, 04:02 PM
  2. Gen 3 5.3L ON3 turbo, my first turbo tune, any help
    By 400ss in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 26th, 2014, 05:52 AM
  3. 6.0 to 4.8 swap Turbo
    By Slowrc in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: January 14th, 2013, 06:58 AM
  4. 06 Turbo LL8 Motor swap into a 240sx Preswap questions.
    By All4bspinnin in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: December 3rd, 2010, 05:01 PM
  5. Closing turbo vanes for turbo braking?
    By Haulinbass02 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 14th, 2009, 12:12 PM
