Results 1 to 5 of 5
Thread: Limp mode after 1/2 shift (pulls timing)
    Aug 2012
    Default Limp mode after 1/2 shift (pulls timing)
    2003 5.3 with 4l60e swapped into a 2003 Trailblazer. Everything works great but when given hard throttle and after making the 1-2 shift, the throttle loses power for a second or two before it kicks in. Almost like a brief limp mode. If I watch the timing during this it drops from 30
    Aug 2012
    Any ideas on what would cause timing to be pulled to -10 during/briefly after a 1-2 shift?
    Post tune and log files.
    Torque Management/Reduction are kicking in, should be able to reduce/eliminate it pretty easily. It's there to save the transmission and soften the shifts, I like to remove around 50% to start and go from there.
    Quote Originally Posted by bubba68ss View Post
    ... after making the 1-2 shift, the throttle loses power for a second or two...
    Also check the shift time tables, 1+ seconds is way too long for a shift.
  1. disable limp mode?
    By 0rion in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 27th, 2014, 01:47 PM
  2. Limp mode, shut down?
    By JoakimMD in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 22nd, 2009, 04:25 AM
  3. Limp mode - On track after quick 3-4 shift
    By dennisscars in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: July 29th, 2009, 06:15 AM
  4. limp mode
    By 69camaro5speed in forum Custom Operating Systems
    Last Post: November 30th, 2006, 10:26 PM
  5. Limp mode
    By ForcedC5 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 13th, 2006, 11:14 AM
