Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: problems with CALC.VET
    Lifetime Member Tinbender59's Avatar
    Jun 2010
    Default problems with CALC.VET
    I am curently trying to get my truck tuned, but. the "data" for calculated VE, not corrected, - Calc.ven is reading "0" what am I doing wrong,
    here are the pids that I am using, should be everything that the tutorial said to use??? calcvet.pid
    Jun 2010
    However, LTFT's are running -1.8 to -4.3 TP and Load are running 26% to 45% pretty much neck and neck. Timing was 26 degrees on up hill to 36 degrees on the flat. Around 70 mph @ 2100 rpm the faster the better.
    May 2014
    is calc.DAT putting out data? Some OSs don't support that PID and you have to create a CALC.B4901 too for CALC.DAT to give valid data....which in turn is required for CALC.VEN.
    post the datalog and calc_pids.txt
    Jun 2010
    Ok will do
    Jun 2010
    here is my current tune and a 30-ish mile scan. On the previous iteration, I did open up the timing, Was limited to 16 degrees, and added 5% to VE across the board. this round, opened VE another 3%. However it does look like O2 2-1 is laying down on me, I have one ordered it will be here Monday. I also have the trans shifting way early, for MPG assistance, she has the torque to handle it. when I go into "tow haul" everything is as stock tow haul for pulling.
    she does run real "clean" smooth and strong, I'd just like to get it correct.
    Edit: I just looked at my pids, they were all Imperial, switched them to metric??? maybe the problem??
    May 2014
    Can you post your calc_pids.txt ?
    Located at C:\Users\YourUser\Documents\EFILive\V7.5\User Configuration
    Jun 2010
    yes sir, here you are. thank you
    it should be the one from the calc thread
    May 2014
    Looks like it's working fine for me, so long as you choose VEN in g*K/kPa units (NOT percentage). As the guide talks about, using the default units is preferred and makes it a lot less likely to screw something up as well. Just change the tune software to display default units in the settings.
    See screenshot below, you can see it's working using default units, but showing zero for percentage units. I think you need to set your engine displacement in the Scan software if you want to use percentage units.. never done it myself personally.
    Jun 2010
    Cool, i say that everything was in imperial and wondered about it. Thank you again
    May 2014
    Units wont matter-- the program can convert easily between all of them and will use whatever units are defined in calc_pids.txt. Glad it was easy fix
  1. Replies: 83
    Last Post: September 5th, 2023, 12:30 PM
  2. Calc vet.
    By dirtymaxlb7 in forum Petrol / Gas
    Last Post: July 11th, 2016, 11:31 AM
  3. need calc vet help
    By whackem04 in forum Gen III V8 Specific
    Last Post: December 16th, 2012, 09:52 AM
  4. Calc VET
    By pormgb in forum Gen III V8 Specific
    Last Post: August 28th, 2011, 10:39 AM
  5. Calc.VET, VET Map Average is all 0.0?
    By n8dogg in forum Gen III V8 Specific
    Last Post: July 15th, 2011, 02:20 PM
