In the log file in post #5 the pid CALC.TRIMMING was not selected.
Otherwise looks to be working good.
I use kPa for MAP, g/s for MAF, g for cylair, g*K/kPa for VE, EQR for fueling, and everything else is Imperial.
I'm assuming he means calc.trimming = calc.cl
ok I just checked my PID's and its there "calc.cl"
Joecar have you gotten your new calc_pids figured out, I would like to give them a try on this stubborn beach!!
ok I think that I am narrowing in on this issue. there are two different tables (or threads on Calc.vet)
first is here https://forum.efilive.com/showthread...se-of-Calc-VET
second one is here https://forum.efilive.com/showthread...ntire-VE-Table.
understand that I have troubles dealing with something that I do not completely understand (at least understand the basic mechanisms of the issue) so as such, I searched out everything to do with calc.vet and built a hard file (printed everything out, and put in a binder) then I study and incorporate it all into a cohesive document, and start from there. could someone explain the differences in these two threads? please? I have! figured out that I should have used one or the other, but I do not understand which one to use.
P.S. I wish That I understood "basic" language programming!
Post #1 in the Calc.VET thread contains almost everything you need (follow the links you see in that post).
Doing Calc.VET is easier than doing Calc.MAFT... Calc.VET is very much like doing AutoMAF (except it addtionally calculates a VE table) (and using EQR and Lambda instead of AFR).
