Results 1 to 4 of 4
Thread: Old T42 tune to new T42 requires updated operating system, segment swap?
    Lifetime Member 68problemchild's Avatar
    Mar 2010
    Default Old T42 tune to new T42 requires updated operating system, segment swap?
    Hi all! Its been a while. I was chasing electrical buggaboes for years only to find my computer was bad. I was running an old holden tune and purchased a newer E38 and T42. The old tune was "segment swapped" and changed to work for the new computer.
    Unfortunately, he did not also update the T42. So I have a T42 with a stock tune that shifts very poorly. I would like to take the old TCM tune and put it into the new TCM. Obviously the operating systems prevent a comparison and update.
    The first tune is the old one I wish to use.
    The second tune is the new operating system with the tune I wish to over write (Tranny tune from fort Myers).
    Thanks in advance for any suggestions. The changes may be very simple but I cannot see what is different by comparison.
    Patrick
    You will have to open 2 instance of the V7 tunetool side-by-side and visually compare the tunes.
    Mar 2010
    Is there any way to do this that is simpler? I got it to compare the changes one time but now I cannot repeat it. What I need is a list of tune modifications. Or to simply install the old TCM computer with the old operating system for the tranny back in? Will the updated OS PCM talk to the old TCM? Can they operate independent of each other?
    Thanks in advnance. PS, more changes than I thought. Lol.
    If the OS's are different you have to compare the hard way.
  1. Emission updated operating system on E98 controller not supported.
    By Chailland in forum E98 2014+ Diesel ECM
    Last Post: January 16th, 2018, 11:06 AM
  2. 4l80e swap t42
    By SEPPY in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 28th, 2015, 01:38 AM
  3. T42 OS Swap
    By SkinnyPedal in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 22nd, 2014, 01:21 AM
  4. T42 4l70e to 4l80e segment swap
    By dmaxvaz1978 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 14th, 2014, 04:00 AM
  5. Reflashing the T42 Operating System
    By S10Wildside in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 12th, 2008, 04:31 PM
