Results 1 to 8 of 8
Thread: Tuning Issues
    Jan 2019
    Default Tuning Issues
    Hi All
    seem to be getting some issues with the ignition and throttle position going all mad when data logging giving the car a surging type feeling when running at a set speed say 30mph with constant throttle. It is a e40 ecu being used to run an LSA engine with a converter for the 24 to 58 tooth configuration. Any suggestions on what could be causing this would be much appreciated have a data log if anyone would like to look at it.
    Thanks Andrew
    Hi Andrew,
    Please post log and tune files.
    If you're running the LPE 58x->24x converter, make sure it is mounted in a location that does not get hot.
    Jan 2019
    Log-base-map-12-3.efi this is the data log
    Post current and stock/donor tune files.
    Jan 2019
    Can't post tune file at present.
    From looking at your log, the problem appears to be due to spark timing.
    Jan 2019
    Indeed its what is causing it that is the issue could a bad MAP sensor placement cause that sort of issue?
    How is your MAP sensor placed and wiring routed...?
    You log shows your MAP signal to be a little noisy.
    BTW:
    You are logging too many pids.
    Remove these: WO2Sxx, ACTLAMBxSx, KNK_E40_DMA.
  1. 5.9 ECM in 6.7 Tuning Issues.
    By comnrailpwr in forum Cummins 6.7L
    Last Post: February 16th, 2016, 05:35 AM
  2. L96 6.0 tuning issues
    By Nver2loud in forum Gen IV V8 Specific
    Last Post: November 10th, 2015, 09:29 AM
  3. lly tuning issues
    By saltflat in forum Duramax LLY
    Last Post: April 24th, 2011, 01:32 AM
  4. Legal issues with tuning
    By Boost in forum Lounge
    Last Post: October 19th, 2007, 07:49 AM
  5. Tuning VZ LS1s any issues?
    Last Post: June 1st, 2006, 12:01 AM
