Results 1 to 3 of 3
Thread: Swapping os?
    Senior Member DieselMafialb7's Avatar
    May 2012
    Default Swapping os?
    got a 07.5 6.7 that came in with a smarty on it and it didn't return to stock correctly so I don't have a usable stock file that is clean and the same os current os is a 11551035 can I switch it to a 11620807 and be ok? truck was a 08 I read out and it had a clean file and optioned similar mega cab with leather? never done os swaps with cummins so don't know if it is a big no no or not
    On this model ECM you can do OS switching but you need to make sure the CalID is a match, that is what defines what the target vehicle is for the calibration (eg, 2500, Manual/Auto etc).
    Eg the CalID might be something like 55351430BH.
    What you are asking above is to go from a 2007 to a 2008 program, that might not work on the truck very well, I don't know.
    May 2012
    Finally found a clean os in the one I needed
  1. swapping ECM
    By seriousdiesel in forum Cummins 6.7L
    Last Post: August 11th, 2015, 08:59 AM
  2. Swapping PCM's, License Q
    By FeetDry in forum FlashScan V2
    Last Post: May 20th, 2011, 01:07 AM
  3. Swapping engines
    By Telco in forum Gen III V8 Specific
    Last Post: March 16th, 2011, 01:32 PM
  4. Swapping OS ?'s
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 26th, 2009, 04:04 PM
  5. need info on swapping 4.3 to 5.7
    By 98_shortbed in forum Vortec V6/V8 Specific
    Last Post: December 11th, 2008, 04:27 AM
