Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Good start tune for Radix 2bar and cos3?
  1. #21
    I'll take a closer look at your files to see why analog wb does not match serial wb.
  2. #22
    Member Ritch's Avatar
    Feb 2007
    LS1B_0029.efi
    above is some "in the garage" torque converter loading I did earlier today. I think the values from the serial connection are looking good now. With the KR I was seeing there, I decided to move all the timing table some. Here's the tune now.
    SD AutoVE COS3 _0002.ctz
    ____________________________
    1999 GMC, rcsb, 2wd, 5.3, XR275HR-12
    Radix magnacharger mp112
    Long tubes true duals, $L60E
  3. #23
    Nov 2014
    did you ever change your b4004 from 0 (zero) above 3200 rpm. how was the car running with these values?
  4. #24
    Feb 2007
    SD COS3_0044.ctzI have not changed the b4004. It is still zero above 3200
    I had been spending time getting the idle to run cleaner and not rattle the blower with the cams lumpiness.
    its been running pretty good so far. I haven't made changes for a few years now
  1. Cos3 01270003 to Cos 5 02020005. Wont start now
    By SuperStepside in forum Custom Operating Systems
    Last Post: September 11th, 2017, 10:03 PM
  2. Brutally hard start after reflash - COS3
    By tirefryin_s10 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 26th, 2015, 03:38 AM
  3. 5.3 with LS6 intake/injectors and COS3 2bar MAFless
    By blindawg in forum Gen III V8 Specific
    Last Post: May 20th, 2015, 03:08 PM
  4. Lean cold start COS3.
    By onfire in forum Custom Operating Systems
    Last Post: July 18th, 2009, 02:10 AM
  5. Cos3 (2bar)
    By aaronr in forum Custom Operating Systems
    Last Post: October 1st, 2008, 09:15 AM
